morning ya'll.
support qld.
already thought of having some people over at mine for the game, but the other half has to be up at 6am the next morning, so she's not quite that keen on having visitors.
i might have to can any plans for the evening, and instead organize something for the next one?
heading out to work now, so won't get any updates till 5:30pm this arvo.
That's why you lost, you can't play cricket while on top of a ladder. :P
Ah, that must be it. We're doing it wrong!
That's an addition that would improve cricket 9001%
F*ck you, dirty pom.
But still, 9001% of 'shit' is still shitx9001
F*ck you, dirty fake injun.
Sheesh, you guys are meant to love cricket. You're almost as good at it as Australia :P
morning ya'll.
support qld.
German Club?
Ladder's in cricket? un astrayen ?
Definetly unastrayen
Yeah but...it's over 9000!
morning ya'll.
support qld.
must have updates by 4:30pm other wise I'll miss the 5:30 train negros. Or I just stay home n catch up on some sleep.
German Club?
Cricket sucks :P
Calling some one unastrayen is unastrayen. Your unastrayen...
<3
<3
awwww
wubs
:P
so whats going on ? we german clubbing? do you need to bring your own club ? or are we ladder cricketing ?? could be the first annual game
awwww
wubs
:P
<3
I'm still keen for german club...
Edited by Smity42
OK Miso is out for german club. He's not keen to head anywhere else instead. But he is going to hit up the better half to see if we can go to his place and get back to me.
Otherwise we could just go without him?
Any other options?
Any other options?
ladder cricket ?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
