I may be able to get my hands on some stocker 33 ones. Would that help?
Thanks mang but nah, it's for my mates 32
They dont fit.
FYI I gave away a pair of stocko ones
Damn you hahaha
The flux capacitor has deteriorated causing a feedback interference loop with the syncromesh gear ionisation device, resulting in dilution of the mechanical lubrication fluid, causing it to evaporate in the combustion chamber and/or bypass the piston sealing devices.
Now THAT is technical
Yup
@John: do you still have that squashed stock bov I gave you? I just sold my turbosmart one tonight and thinkin I might put that one back on if you do
Side note: the TRD laser's going in to drift king next week!! Hahaha!!
So, finally figured out what is wrong with Jason's boost control set up.
What's wrong with this picture?
Hint: Symptoms include infinity boost, and (I presume) BOV not working
I can't believe I didn't spot it when I looked last week, my excuse is I was drunk on JB :)
I'll let you all guess for yourselves which 'mechanic' is responsible for this quality work.
martin get an abn, get on a supplier list who happens to source many different brands/parts, and start a business.
ive joined the same supplier with my abn, and did it drunk - so its easy to start...
:D
I've got better things to do with my time. But I'll keep in mind you can hook me up with parts :D
Shitbox 75 had a transaxle with LSD in the boot. f**k yeah, $1000 saved.
Morning mangs, scarnon?
hey marto
cool xf.
needs more;
While it does rip a mean skid, I have 1 2 3 4 other cars that would be better for drifting than it.
That's what she said
Sure do. Come on Thursday and get it :)
Sweet deal..... can't make it this week though, got a dinner with a bunch of people in the valley then going to watch a play at griffith.
PM you who your "supplier" is
I worked for Pizza Capers for 5-6 years..... it's great. I can't eat pizza anymore as a side effect, seeing as I used to eat it 4-7 nights a week
pizza Capers :down:
Hell's Pizza ;) as I now drive past one going home from work
While I agree with you hell's pizza is awesome, capers does not deserve a thumbs down. I do wish there was a hell closer to me though ;)
The local capers seems to have a policy of hiring hotties though, and this I approve of.
I worked for dominos for 6 years, also used to eat it about 4 or more times a week. I can still happily eat it though :)
While I agree with you hell's pizza is awesome, capers does not deserve a thumbs down. I do wish there was a hell closer to me though :down:
I remove the thumbs down as they are good pizza's
Then there's no debate at all. Pizza Capers FTW.
;) but still going to hell's pizza tonight as it's practically a drive through on way home.
Jason's blown a turbo seal from his mega super infinity boosto!
Dam that sucks
pizza Capers :down:
Capers > Hells AINEC
Hotties + Pizza? New destination for thursday night meets?
Sarp Mangs. Hot new graduate started today. It's awesome.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
