Pretty much. But we have a housing shortage right? Not at all like the USA they overbuilt and...wait a minute....
As much as I would love to see house prices have a 40% correction overnight it would pretty much cripple the economy which I guess is a bad thing. It has to happen eventually though.
apparently i costs less to buy in New York than Brisbane now...wonder how true that is? I bet its not the case.
Check on ze internets?
You'd need to know what parts of the state compare to what parts of Brisbane though. I imagine some of the stuff up north would still be pretty exy, even if the city has dropped a bit.
FYI:
L1/SP126944 26/11/07 460,000
L2/SP126944 09/01/09 450,500
L3/SP126944 02/11/08 420,000
L4/SP126944 15/08/06 370,000
L5/SP126944 26/09/06 398,000
L6/SP126944 27/07/03 311,000
L7/SP126944 17/05/07 425,000
L8/SP126944 02/05/06 365,000
Lot 2, will be your biggest problem. IMHO we're in the same markey as 07 and 08, thats where price's are back at. Go in hard with a clean contract would be my advice
Depends how you look at the stats, if they are based on average incomes then yes it is true, otherwise it’s total BS
FYI:
Cheers even 450 is ok, I will get my sister to come around and make the agent cry, that should lower the price a bit
oh yeah i forgot about the whole adjusting to salary thing
Couldn't be bothered reading the last two pages......... too much serious bizzznatch bout money and houses.
Sooooooooo I'll just leave my input as:
SOMEONE GIVE ME 11ntyHUNDREDDOLLARS SO I CAN GO TO DEFQON1 IN SYDNEY
baaaaaaaaaaaaaaaaaaaaaaaahhhhhhh
/rant
DAM BUSTER TOUR UPDATE!!
The tour will be on this weekend ( the 12th and 13th of June ). After some numbers who will attend. It will be on in the after noon after 3pm on the sunday. If no one can make it, I will wait to hear back from Graham regarding another date. Beers will need to be provided as payment, as well as to drink. If we all chip in we may even be able to have a BBQ at the dam afterward.
EDIT : Forgot to mention max numbers of eight. BUT if it is a popular day then we can organise another one
IN!
In. You fockers can pick me up on the way through?
I was saying :D this weekend ( the 12th and 13th ) I was specifying a date sheesh
You are a confusing mang.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
