Looks like a few newbies. shame I miss out
yet again
Nice work above and beyond thanks GaraGe31.
What are you doing in here Rangamister? Aren't you s'creaming it up ?
Martin: I left a message for the guy with the crashed GTV. I'll let you know if he gets back to me.
Tristan: Can you please have a look and see if you still have the rear speed sensor from your 32?
yeah, had planned to get out there, but ended up having a few too many drinks to drive there
instead sat on my couch and played modnation racers. whoooo :)
So i get into the office, fook all works. Server is missing. Turns out its been changed, upgraded - Who knows. When? Should be done around miday.
me - so we're all doing what until then?
Office - Well the net still works...
ROFL
I REALLY want to post this on the lowballer forum:
I'm teaching a young girl how to drive and she just can't get the hang of putting clutch in before changing gears.
It's just nature's way of telling her she should get back in the kitchen
:blush:
But I have my mod hat on and not sure if I should...
Edited by Smity42
same hey
I'm researching brake options for project alfa. I don't think the 32 brakes will work :blush:
Why is it a no go?
lol. You're a mod over there?
Why is it a no go?
Too small for the front (sounds crazy I know, but if I'm going to customise the brake setup I'm not going to do it half a*sed), too big for the rear.
Theres some 4 piston 330mm alfa brembos on ebay I'm keen on.
Jawol. Sucks being a mod, I'd have posted it in an instant if I wasn't :blush:
I give it about 10 mins tops till I think "f*ck it" and post it anyway.
Jawol. Sucks being a mod, I'd have posted it in an instant if I wasn't :(
Yeah needs more 355mm rotors and big 6 pots. :blush:
Link to thread and I'll post it lol
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
