I have white skinny jeans. I do not look like a fag in them, at all.
also spotted Dan in some homo as CRV near James St
Me? in james street?
only if CRV = Maserati Gran Turismo
edit: A page to me!
Edited by Dan_B
Bull shit, i saw something that looked like the XXXX man driving a CRV
Wasn't me. I was on a test drive in that area at 3:30 - 3:50 but i was in the maserati that i have been replacing interior trim on for the past 3 days
with a proper auto box in them they are an awesome car to drive, the F1 and Cambrio Corsa are just crap driving around town in stop start traffic, but for really getting up it i'd go a proper manual box. Cruising around new farm was good fun
auto FTL.
I don't care if it's a triple plate clutch and I stall it every 3 feet. I'll be too busy beating off in the driver's seat to care!
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
    • Well, I was using ECUTalk software if that helps? Not sure if that only can see engine codes? Is there any other software I could give a try? Or any way I can get a blink code?
    • I never touched it, it should have. I'll try to give it an adjust. With IACV plugged in, it idles at around 1120RPM on average. Max 1200 RPM, Minimum 1025RPM before it starts dropping right before stalling. Took the data from the Nistune logs.
    • Thats what im trying to solve bro  no one with aem tuner experience would advice  much appreciate
