I could give you a reference. I've seen your hand work :domokun:
BAHAHAHAHAHAHAHAHAHA!
Job for John
Needless to say I was expecting something different.
Still as feminine however.
yeah, me agains...........
I'm well. How bout you guys?
I slept my whole day off :(
im pretty good 1 exam down 4 to go
I've got one module to finish by the end of the week. Fun stuff :domokun:
so today was another all day service, road test is tomorrow morning.... josh, what time do you want me to blast past your work with open pipes from the 430 Scuderia?
BTW jas
You wanta find skyline drivers in Toowoomba?
Go hang out in Ruthven street while they do burnouts all hours on the night on Thursdays while im trying to sleep...
Just too many "kids" in them these days wreaking the "image" of skyline owners in general...
Now I own fast cars & bikes that "tools" cant afford... :)
Edit: Now some older bloke in his 40's is saying on the forum he subscribes too "Too many kids (ie. me) driving these cars these days, time for me to by a S class Mercedes"
