woot woot
i has a booking for moo moo's in the city tomorrow night...
woot woot
only the best 5 star steak restaurant on the gold coast, now available in the Stamford plaza hotel in BNE city...
woot woot
and ill be there with beer in hand... :thumbsup:
f**k yes... f**k yes...
can believe my dreams have come true... moo moo in Brisbane...
jizz
Gents,
Just for curiositys sake, what is the fastest street car around besides the veyron?
Im looking for one factory example and one modded.
Dont have to be the same car. Just looking at power figures.
Cheers!
bought steak fails
Jap ox export from my brother in law shits on anything we can get here :D
I'll disagree there, grass fed cattle with no meat preserving and the fact that it was a fresh kill and never frozen, even better. Also lamb in the same way. I seriously have not tasted better.
Next time i head west i'll be taking my "large" esky.
Must agree with you there. When we used to get fresh goat curry. it was the BEST!
Fresh as in, slaughtered that morning, marinated through the day, cooked at night. AWESOME!!
Ask any ricer racer, any real ricer racer... and they'll tell you it's a Honda
Edited by Isola
Thats exactly what im talking about, whenever a load of cattle make the jap ox grade one is always kept by my brother inlaw at his farm and killed there. We used to have our own on a very regular basis but sold the farm so now we have to wait till i cant get out to his farm to get some.
yer, this was fresh tony, as in the meat was still warm when i was cutting it up into lamb chops..... hahah!
fastest street car? in what way fast? straight line? or corners?
on a tight track/mountain pass i would lean towards a Lotus Exige Scura or an Exige Cup 260. Open track like QR, probably a Lambo Murci SV, or a F430 Scuderia. Straight line.... who cares?
That's basically what happens at every meet
THIS JUST IN: TRD LASER 1 - dead in the water.... will cost too much to reco the head and fix the valve issues.
So everybody welcome:
TRD LASER 2!! Now with moar 'luxury' ghia features, and more quirky electronics than you can poke a stick at! On the plus side, my extractors will still bolt up to this one :)
fucksake, I would have GIVEN you the alfa motor to put in it in exchange for a few nights with Tarlae :D
Andy, moo moo's sells export grade master kobe on a POA basis...
approx $200 per 250g steak...
and its brilliant... the fact i don pay means its brilliant... Id be disappointed if it were outta my pocket...
$200 could buy many good steaks... :D
Does anyone have any people on their MSN contact list who just won't say hello until you do? And if you don't say anything they crack the shits before they go offline because they waited all night for you to say something? I have two. They get blocked for months at a time because I'm sick of being the one who always has to start the conversation lol
f**ksake, I would have GIVEN you the alfa motor to put in it in exchange for a few nights with Tarlae :D
I wish I had that authority! Hahahahaha believe me, I do!
Ravi,
i'll trade you some mechanical assitance for tarlae..... ?
Mate if Marty has no Tarlae loving, then you sure as hell don't! Get in line! (In the nicest way possible :))
I used to back in high school...... I've since either deleted them or they don't come on msn anymore. Most of my social networking is facebook-driven these days though so I'm not worried hahah
i have a dickload of people on my msn list that i never talk to, ever :P
Hehehehe you said dickload
hehehehehe
he said dickload
Awwwww
facebook chat is a cunt though...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
