Group interview?
Had an interview today for a call center job in the city. They did a group interview. There were 28 people there, for 3 positions. It was the gayest thing ever... we all had to do little quizzes and answer questions, and then play those stupid "ice breaker" games and we were rewarded with mini mars bars for being awesome... I got three mars bars, a headache, and a HUUUUUGGGGGE desire to kill.
I might actually watch that game, depending on what time it is.
I'll barrack for germany though :cool:
That will please Die Fuhrer. Its on at midnight on Sunday though.
now untill 6pm is going to go SOOOOOO slowly :P
Not for me mang :P
Group interview FTMFL :verymad:
What's the interview for?
Sounds awesome :cool:
I got told all the stories about how hard it is to get a job with Multiplex at our cadet camp thing. Everyone has had to do 2 phone interviews, group interview, psych evaluation, panel interview and then a final interview with a director lol. Application process took some people longer than 8 months lol.
I had 2 interviews in a week and started 2 weeks later. :verymad:
That's what it's getting like in lots of places now. I had three phone interviews for one place, and then didn't make it to a real interview. Had several other phone interviews too.
This one today was a phone interview first, group interview today, and if I make it through that then there'll be a face to face interview as well... wonder if there'll be more mars bars? :P
ghey. sounds like high school :verymad: but maybe with that many mars bars you might get a job?
HAIL!
Midnight's not too bad, better than 4:30am :cool:
Not for me mang :P
B4stard! I'm normally on my way home by now, but I have to sit around with basically nothing to do, to wait for my outage window (6pm) :P
that blows man
everyone talking about "wow first female pm" etc etc
all i can think if "first ranga"
and wonder if she has a ranga landing strip?
Correct :verymad:
I worked mhy butt off. Went through 5 interview stages, 3 weeks of unpaid training and exams - completely unpaid. and then on my first day lost the job because I was 15min late. Im still spewing! anyone work in real estate? want to offer me a job?
Damn, is this the stuff you were talking about last week? That blows man
15 mins late though on the first day, I'd have fired you too :verymad:
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
