officially requesting transport for 3 people between city and german club tomorrow night. Or further northside if anyones coming from that way.
Who can help? ;)
I is already full baby
mang I have no idea. I'm guessing I swap trains at beenleigh around 6pm but not sure what time the train gets in to kuraby. might be easier for me to just take a bus to southbank and bus it in
As soon as you mention the word wedding to anyone in the industries which help facilitate a wedding the pricing doubles...
All I want is a match pair of black 300c's to follow our car (1955 Rolls Royce)...
Cheapest I can find is $595 for 4 hours... What a f**kin rip... They are just 300c's with a driver not flaming supercars...
Im paying double that for the Rolls but its a car worth a cool half a mill... So its worth it, but to hire two cars worth $58K driveaway when new i a joke...
Ideas?
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
    • Well, I was using ECUTalk software if that helps? Not sure if that only can see engine codes? Is there any other software I could give a try? Or any way I can get a blink code?
    • I never touched it, it should have. I'll try to give it an adjust. With IACV plugged in, it idles at around 1120RPM on average. Max 1200 RPM, Minimum 1025RPM before it starts dropping right before stalling. Took the data from the Nistune logs.
    • Thats what im trying to solve bro  no one with aem tuner experience would advice  much appreciate
