mangs
picked up z32 today, and picking up eboost tomorrow
car is ready to go in. just trying to find a cheap rad. anybody know of any cheap koyo's or similar going around?
dear john,
man the f**k up and do this;
<3 tristan
Shall I give you my bank details so you can transfer the money for that conversion?
PS My car already sits that low (that just looks lower because of the skirts and front lip). And my car does it better with stretch and better fitment.
<3
Hahaha.
On a side note, how much do you guys reckon I can get for my tyres? Bridgestone Potenza RE050A 285/30/18 70% thread.
Thinking of getting 265/35/18 instead. Maybe the front wouldnt scrub if I getting smaller tyres.
