After researching it seems like water pump failure isnt that uncommon. The car has never been overheated before but I've filled the reservoir up 3 or 4 times with coolent since my last service (8000km).
I can see coolent residue on the car when its up on hoist too but never a patch of green stuff when I park.
What I wanna know is how is the system diagram like... what goes where. I might try googling and see if anything comes up.
ps: I'm hoping its the water pump because I'm changing that out this weekend for major service!
Wow you do long service intervals. Mines lucky to see 5,000k's without the oil and filter been changed.
Yeah I've heard the water pumps do fail a fair bit. Make sure they put an n1 item back on since your car is an n1 and not a standard pump. They aren't much more and if the car gets rev'd a bit will help stop cavatation.
The bottom of your radiator hose should go into the water pump which is on the front of your engine.
Up the top should come out of the head and into the thermostat and then over to the top of the radiator.
From the radiator cap there should be a line running to the resevoir.
Also there is a Thermo switch at the bottom and a drain plug to check.
There is a air drain plug in the side of the head, just in front of the injectors
And then there are the heater lines that should come from the engine block/head and run into the car. One of mine looks like it comes from the thermo housing and around the front of the engine. Not sure but maybe someone can clarify this.
@John, Phil
I is going to take a 'strayen day tomorrow, but I don't feel like driving to aspley just for the privelidge of driving back to petrie :D. If you can give me a ring when you leave aspley I'll meet you on the way
Phil, if you have my alfa bits back can you bring em along? If not, don't worry.
@John, Phil
I is going to take a 'strayen day tomorrow, but I don't feel like driving to aspley just for the privelidge of driving back to petrie :P . If you can give me a ring when you leave aspley I'll meet you on the way
I am also taking a strayen day tomorrow but have to pick up my daughter so will only be making the trip some of the way. Tim have your alfa bits will drop them off tomoz.
You owe me :P:D
i wouldnt mind betting you are losing that water from where the top plastic tank joins the main core of your radiator, super common
Thanks for that mate. I hope that'll be fixed this weekend. I have already order the N1 water pump. Gonna keep the car as close to stock as possible.
The service duration of 5000km to me is over the top (I cant never understand why because factory doesnt even do them that often). I dont flog the shit outta my car and at the same time, my mechanic told me royal purple is good for more than 10000km if I wish but he'll set the next oil change at 8000km. I've been doing that for the last 2 oil changes and the car drives like new.
Well Ive just come off the track, in a good way (via pit lane)...
PS> This circuit makes my bunghole shrink rapidly coming into the corners...
We are now got a hour to relax and eat before the debriefing and timing sheets come out...
Im starving just wanted to log on to update fb... :D
That is f**kin awesome. Prodrive are pretty involved in the WRC aswell aren't they?
Ummmm not sure... I know they big into circuit racing, ill ask...
Yeah as Bunta said, check your core.
Sounds good mate. Yeah I do it as a safety because as an engine gets older the rings allow more blow by and with the increased boost its not really helping the matter. lol Suprisingly my gtr has very little but good insurance. With the fuel dilution of the oil it does affect it fairly badly and can also lead to pitting of the camshafts, etc. So thats the only reason I do it. Each to there own.
How much do you get the royal purple for and where do you get it from if you don't mind me asking? And what grade do you use?
Heard some good stuff about this.
Cheers
Edited by 32vspec2gtr
So how does a general smo ( i.e me ) get to have a crack at what your doing ?
Say what?
I have just worked two 12 hour days and was supposed to have my daughter yesterday. So because of that I have to pick her up tomorrow. She lives in ipswich so I'll accompany you on part of the trip and leave you when i get to ipswich. If thats to much of a issue then I won't be able to attend at all.
That's because "factory" normally doesn't service 15-20 year old cars (with a handful of exceptions like the ones Dan works on). Especially when they weren't even sold from "factory" in the country.
You will find that a lot of places change oil or spark plugs (or at least clean the plugs) every 5000kms though. And yes, your oil may be good for 8000/10000kms... but is your filter good for that long too? I'd at least be flushing/dropping the oil, replacing the filter and putting the oil back in (which is probably what your mechanic is planning by making you come in 2000kms early). It's not just about how many kms are on the speedo either. If your car idles a lot, and you baby/granny it and never get into high revs territory then you're going to get a lot of carbon build up that needs to be taken care of.
You should also regularly check the spray pattern on your AFMs to make sure that they're not restricting you :D
But as Matt said. To each their own. If you're not into regular maintenance and just want periodic maintenance then fine. I'd rather spend a couple of extra bucks and give my car the best though. You could save heaps of money by doing all the minor services yourself too... just fyi.
So are you going to be going to Ipswich from Somerset? or...?
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
