I'm going to grab the 30e next week. Dad and I will be taking the engine out tomorrow and Sunday. Back on the road by week after next?
need a hand tomorrow?
give me a shout.
Protip: engine + box out together is by far the easiest way. Then bolt box to new engine and engine + box back in together as well
I can't come help today as I have to wait for the mobile thread repair dude. Tomorrow I might be able to
If you end up with a spare set of engine mounts - shotgun
I'm just there to get in the way
That's what she said
Anyone knows if you'll need different spray paint for plastic???
You need to use plastic primer
Opinions ppl?
or something a little more Michael Westen-ish
I like these ones but they don't come with a black iridium lense :)
Opinions ppl?
I like these ones but they don't come with a black iridium lense ;)
Either of these get my vote. My last set of Oakleys got stolen from work :P
1. Martin - get the third pair from the top. The first ones wire frame ones.
2. Green Lantern FAIL:
This is what the costume is SUPPOSED to look like for the particular Green Lantern that Reynolds is playing:
Side note :
A friend of mine is getting fired today she was trying to set me up with her friend on facebook (during a working day apparently) she mentioned she has large bewbs. The IT section logged it as porn and now she's getting canned.
LOL
Side note :
LOL
f**king lolacaust
2 x $300 + postage $52.67 + admin fees $104.40 + special cleaning cloth $7.28 = $764.35 Total.
But what if I winked at you thusly
What would that get me ?
f**king lolacaust
She's asking me what to do. I'm like nothing you can do. I did however suggest that since she is getting fired today that she should get her t_ts out on cam for me.
+ winking surchage of $14.58 = $778.93 total.
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
    • Who tuned it? Have you spoken to them about the hot start issue yet?
    • injectors were upgraded (1000cc), stock turbo high flowed, return flow infercooler and ecu nistuned before tuned
    • Injectors? Note, there is no way that I would run E85 on stock injectors. They are too small.
