She's asking me what to do. I'm like nothing you can do. I did however suggest that since she is getting fired today that she should get her t_ts out on cam for me.
This would be my advice too
Bahahahaha it just keeps getting better.
She moved to adelaide for this job. They put her on a 3 month probation. She is still in this probation and the boss and some other dude want her gone so accuse her of porn at work. lol
She's like what do i do... I said my offer still stands. She said what offer. I said t_ts on cam. She hung up on me.
Engine is ready to come out tomorrow. Everything is disconnected n shit so pretty happy. Only took us 3 hours so pretty happy with that. Time for Glenfiddich
So after about 6 hours of work over Saturday n Sunday this is what we achieved
Great success. Terri got a photo of the tractor with the motor hanging off it so I'll grab them someday lol.
All good mang. Dad might be working in Petrie during the week, any chance of borrowing that engine crane for next weekend? The tractor is fine for taking shit out but it would be a prick to put it back in with it.
looks like a decent effort for the day
in other news, got some track rims with brand new potenza tyres on them. that will do to start with
car will hopefully going to erd in 3 weeks, and then should hopefully be ready to have some fun
Ask dan, it's his...
nice work colin, if you want to borrow the crane no worries. I'm cool with it.
I've had a reasonably productive weekend, done some electrical work on the white car, rebuilt the shocks on my bike, some more panel work on the blue 31, and got the tail lights out. Sikaflex is horrible stuff when used in excess. 3 hours and a hot knife took care of that though
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
