mmm V6 engine removal today. 2000km on the car and the driver forgot to stop..... Quote for the repairs is almost $20,000 as of this afternoon
This sounds interesting and I demand more information/story!
Not sure on the full story how the crash happend, but for the damage the car has come off very good
thats how it turned up this morning, doesnt show how bad the damage is, both rails are bent towards the passenger side, the gearbox end is 36mm pushed back then its ment to be, the suspension K - frame has flexed enough to crack the welds on the passenger side, the whole front gaurds/bumper/reo/headlights/radiator/condensor/thermofan's are toast, and it needs a new engine loom harness ($2250)
took me 8 hours of work to get it from that stage to engine on a mounting frame and the quote sheets done up.
Today = epic fail. Checked pickup in the sump this morning all fine. Put a new sump gasket on anyway. Took the clutch off of the old motor and its pretty much down to the fasteners which sucks. Also the new motor is from an auto 31 so need the spigot bearing so the box will go on. Tried to get a clutch today but the only place that had one was Bursons in Slacks Creek and they shut at 12. So I missed out.
Sold my old school volks though so that pays for the motor and clutch.
Plan of attack now is get the clutch and everything for Thursday then chuck the motor in Thursday and then finish bolting everything up on Saturday after work. I am disappoint.
thats a shame dude
I tried to get on to you to come help but you ignored me :thumbsup:
you'll need to get the auto spigot out, that will be heaps fun. Check it out: http://wiki.r31skylineclub.com/index.php?t...bearing_removal
I recommend the dynabolt (with weight) method. M20 dynabolt for an auto i think.
No cruise for you on saturday then? Unless you and dan take dans car...
You probably should buy a button clutch or somethign since its going to be a drifter. Hit up kudos during the week, he can prolly get you a spigot bush as well
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
