Is that the 31st or the 1st? Might be able to make it if its on Sunday. Kudos called to confirm clutch order. Should be delivered by Wednesday. Thursday = Clutch n box on maybe get engine in Thursday. Saturday afternoon putting everthing else back on and ready to roll Sunday?
WHATS UP?! :)
hey marto i saw you liked my little post about 31 suspension :P
it was dedicated to both you, col and dan <3
Won't be able to make it then :P I'm working on Saturday and then got to get the engine in.
which saturday bro?! ill come help you get it in!
Weak :P I guess Dan needs a new Nav then...
WHATS UP?! :)
:P
Mine is lowered on several grand of custom suspension, but I love a good lowballed, cut springs, flogged out pedders/munroes 31 pig any day of the week. Particularly if you just want to be baller, and don't care about, you know, handling n sh*t.
huh handling?
:P
i lust your bilsteins
WHATS UP?! :)
This Saturday mang. Welcome to come round a lend a hand.
:P
I am disappoint too :P
Thread needs more e wang suspension
I have ohlins at home...but on the car is Teins :S was going to swap over but for some reason the Teins fell like someone has gotten them right
lulz
ps i made your sig! EPIC WIN
There is no greater achievement in this life, than making my sig.
Mmmmm... ohlins
Teins :P
keen as mang!
i know, my life is somewhat pointless from now on...
Just had a conversation with a foreman about a scissor lift I need for tomorrow. Had to use scissor far too much in that conversation lol.
Heya :D
Yep, I'm back in Aus now - landed this morning at 7. Buggered if I'm reading through 8 weeks of pages on this thread but I'll be along on thursday night :)
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
