speaking of sammich its time for lunch!
building mum a computer today out of spares, although i did buy her a new video card, its more powerful then my old one :woot:
anyone got a 120mm hole saw they can lend me? new PSU needs to vent out of the case
getting hungry too. ducked out from work early.
managed to get myself into a bit of a pickle with our friendly constabluary
will update as events unfold today
did they find a "cop" In your boot. ;)
a freshly butchered one :P
will just update everyone on thursday, this being a public forum and all
don't think it will trump isola's story tho. that was a crackup
I need to borrow r34 LH & RH mirrors for compliance.. PM me if you can help
How can you borrow mirrors ? ;)
More importantly if you guys want to have a look at some... a lot of skantly dressed women pull up a chair on racecourse rd around 430pm. There was so many heading up that way about a hour ago... :P
Evening all
Somebody may have a car in a workshop getting work done or car could be off the road for some reason.
There are endless possibilities but i will leave it there.
they have white faced ones as well with red dials, but thinking of sticking with black as it will match my standard cluster
def stick with black.
They look pretty sweet. I approve :)
+1
How can you borrow mirrors ? :worship:
More to the point... how do you then get your complied car roadworthy once you've given the mirrors back? and if you get it roadworthy THEN give the mirrors back... how do you not wind up getting defected to the Nth degree? Sounds like a foolhardy plan to me.
compliance is alot more strict then a roadworthy john, when a car comes into the country for compliance these days it's got to be pretty much 100% stock.
For a roadworthy you just got to have side mirrors of flat glass, nothing special. Guessing this 34 has aftermarket ones?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
