Wtf are those coons up to this time.
decided tyo play loud music at 2:15 in the morning, I called the cops, they turned up at about 3:30...then the dumb f**ks decided that it was still ok to sit out side and talk durka durka at each other and clean up their bottles. I couldnt hear them as much downstaris so i must have fallen asleep right after i typed the above post that i dont remember
Boat people?
I would say so, if Abbot reckonc he can stop more of these flamin mongrels coming over he has my vote
If abbot reckons he can keep women in the kitchen he has my vote
...wait no he doesn't, he's an idiot
...wait they're all idiots. FFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUU
Edited by Smity42
you don't ring the police you ring the epa they give out huge fines.
I am delegated under the EP act to serve penalty infringment notices, they are getting one of those too but the police stop the noise in the short term!
your only other option is fire :huh:
If I voted this would be a +1
Google yesterday had "celebrating 90 years since women got the vote" under their search bar... Another good reason to use Yahoo! :huh:
ORLY?
*noted for future reference*
AHAHAHAHAHAHA, thanks for the laugh :)
@John, Joe,
Sorry but I feel the need to back the rear admiral up and I refuse to violate my policy of not posting on faceparty. Hell pizza is awesome, and I wish there was one near me too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
