He hasn't been back at my place since, and haven't heard anything, so am hoping that's the end of the matter.
thats the going rate. I will have one here tomorrow night if you do no good there. Mint. (hate that word)
My guess would be a light automotive course. Seems like every new apprentice we get these days is a knuckle dragger too lazy to do a decent days work
Ok so i went to my local tyre shop this arvo. Question to y'all does anyone want new rims?
I can get 2 sets:
Work Meister S1
18x8 +35 / 18x10 +22
Polish Silver Finish 2 peice
Offers around $2500-$3000
Work Emotion XD9
18x9 +30 / 18x10 +22
Magnesium Finish
Offers around $1500 - $2000
They are brand new in box never had tyres fitted, all 5x114.3 and all legit. If you want them PM me and i'll put you in touch with them
Far out those XD9's are cheap. Tempting.
make an offer miso, he wants them gone.
If i had a complete 5 stud conversion ready for my 31 i would be buying those Meisters.
Meisters do kick ass >_<
What is it your doing at tafe..
see below
got it in one >_<
This is a new one :S
fitted 20mm spacers (very good quality ones from japan) and long wheel studs for the spacers to eliminate the bolt on studs.
So you are using bolt-on spacers as slip-ons?
they are bolt on, i have removed the bolt on bolts to allow the long wheel studs to go through instead, plus i heard that is a lot safer
lol thats not safer at all
i got told it was safer by a wheel shop to run spacers like this, so there is less stress on the indside wheel studs on the spacers. they advised me that they wont snap like this.
The wheel shop in question must be a bunch of incompetent twats.
Final quote was me >_<
quoting is where its at col.....
although i hear its better to only run 2 studs with spacers to reduce the stress...
geoff you know you want to buy sweet rims...
Sweet rims indeed. But no, not interested today, sorry. I'm happy with the ones I've got (not got the spare cash and theres more important things to do to mine first anyhow).
John's day at school
I went to an Epson training day a few weeks ago which pretty much entailed of me doing everything really really quickly so I could get the f**k out of there before someone would ask me where I work and then proceed to tell me how much better their job is than mine for the eleventy millionth time.
On a side note, checked all the hoses tonight on the skyrice, I didn't have enough light but I could hear a slight psssss sound, so I'm going to replace the hoses from the boost controller + bov.
Oh, and John if the series 1 afm pwnd had will work on a series 2, I'll come and pick it up from you on friday or saturday if that's cool.
Tell Andrew that if he wants someone who actually wants to do the work, and actually wants to learn, that I'll still come work for him. The course is done in 4 weeks :(
PSSSSSSS noises aren't good in.... See if you can get a leak tester :D
As far as I'm aware - series 1 is green, series 2 is pink. I only say this because when I was looking for one I got told a green label from a series 1 25 would work on my 20. *shrug* Best bet is if Miso can bring it along, I'll just grab it and we'll try and see what happens.
Jason has some spare coil packs for a 25 now that I think of it. Maybe he'll let you borrow them to trouble shoot further if the AFM isn't the problem. You'll have to ask reallll nice like though :(
Noel, your car is Mint.
@John: Lol
Alvin ROOLZ
I can do better in the wheel department.
Howbout a set of brand new nismo lmgt4's in 9.5x18. +30 offset with new tyres for 3500....or...Da bomb...Volk GTC's in black with chrome lip gtr offset +12 9x18 with feddy semis 50% tread mint for 3 kay.
