Afternoon gentlemen.
How was the weekend? I was in Sydney with the training crew. Saturday was the spent hiking around the Blue Mountains and the Jenolan Caves. Awesome stuff. Sunday we spent it at Darling Harbour drinking in the sun next to the opera house. Epic BBQ on the Friday night and last night.
McFly, the Car looks horn with the GTP's. I would have come for a look-see if I was in the state. I fly back tonight.
McRae, Nice work on the B2B. Sub 1hour. Aewesome.
Edited by SABBAi
yeah mang pretty decent i reckon anyway. Came like 6130ish out of 40k people lol.
Evening, squire!
Sounds like an awesome weekend.
I spend saturday turning the alfa into a 300zx (engine out!), and generally piss farting around. Sunday was lakeside. Also much F1 all weekend, FTW.
Mmmmmm nice little track rims they are. Back on advans now.
A likely story...
McRae
I like it.
Side note I just won a ride in a drift car... should be awesome.
At archerfield?
Sorta depends on which driver/car you get put in as to how good it is
Got pulled over this morning on the way to work (a whole 2km) apparently my car isn't registered, although I have the sticker and certificate to prove it and I was shitting myself at this point thinking that a fine would be the last thing I needed right now. Cops accepted the sticker after having a fiddle with it. Would have been a different story if it was a cop on his high horse.
Would anyone happen to have a spare battery that holds charge alright until I get a new one? It's for my falcon, the negative is on the left and positive on the right. Only saying this because the one I got from someone today was opposite and the leads won't reach that far.
At archerfield?
no its at acacia ridge. should be fun anyways. driving un-registered car is a 2 week impound.
Reportin in
Realised that I have a replacement exhaust for my laser sitting on the parts laser in the garage, that is minus one muffler... so removed that on sunday arvo and ran out of time getting it on the 'good' laser before the sun went down, plus cbf hahaha.
That along with the stractors should give it some bang in the noise department hahah.
Also just been offered 5g cash from some boost loser for my 33. f**ktard.
P.S. compressor + air tools makes anything mechanically-minded soooooooooo much better..... oh my god I can't believe the difference
wouldnt be without them. :P
I sold my r33 for 5k, eventually you CBF having it in the garage any more, I would have taken a hug for it thats how sick of it I was lol
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
