Blasphemy!
A minor blasphemy, easily forgiven (We did have a Milton Reformation).
Going elsewhere or some other time and then saying "X was > Green > *" is a different story.
Hmmmmm...... OK then
That would be a keel-hauling offence
In order for X > Green > * a unanimous decision would have to be made by impartial judges after thorough investigation of X. Agree?
NO! X can never > green as long as the one leg is both the same. :action-smiley-069:
A thorough investigation of green and all it's surroundings would also be required. I volunteer myself for all required investigations
f**kin lol Martin. Nice work.
Just had epic argument with tiler/glue seller guy. He's a douche.
I had an epic argument with a builder yesterday afternoon. Apparently windows 7 should be covered under warranty, so when he f**ks it up he can bring it back for me to spend 5 hours fixing and he won't have to pay anything for it. So I put the question to him, if I got him to build me a house and then I knocked a wall down inside it and the house falls down would he have to build it up for me again?
Ah but then if it could be ascertained that the one leg is both the same and the impartial judges ruled in favour then it could be established that X > Green > *. Correct?
I concur. I believe we should organise a committee to proceed with aforementioned investigations.
Finding impartial judges is like f**king for virginity. :action-smiley-069:
http://www.youtube.com/watch?v=7ya-v-jchr0
R34,33,32 review on top gear from way back. I haven't seen this before so maybe some other guys haven't either!
yes colin he did, its currently been sitting in the workshop since monday arvo though with a coolant leak from a turbo line, its almost an engine out job to replace this 4 inch length of hose!
It's not too bad, taxi spray red but generally a clean car couple minor mods here and there, although he wants these modena rims.
Also tell your dad to buy that cortina, and i'll remember to bring some empties for you tomorrow night
Happy Birthday John. Rock on I says
Cheers mangs!
Not feeling the <3 no more..... :(
And
HAPPY BIRTHDAY JOHN!!!!
if you didn't see it due to post skimming........ :action-smiley-069:
Edit: Happy Birthday John! hahaha.
:D
That's the S1 review from the silly fat fucker that Martin and I were talking about.
Not feeling the <3 no more..... :)
And
if you didn't see it due to post skimming........ :(
Didn't see it! Was skimming! Sorry
Mucho thankies and epic <3
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
