Blasphemy!
A minor blasphemy, easily forgiven (We did have a Milton Reformation).
Going elsewhere or some other time and then saying "X was > Green > *" is a different story.
Hmmmmm...... OK then
That would be a keel-hauling offence
In order for X > Green > * a unanimous decision would have to be made by impartial judges after thorough investigation of X. Agree?
NO! X can never > green as long as the one leg is both the same. :action-smiley-069:
A thorough investigation of green and all it's surroundings would also be required. I volunteer myself for all required investigations
f**kin lol Martin. Nice work.
Just had epic argument with tiler/glue seller guy. He's a douche.
I had an epic argument with a builder yesterday afternoon. Apparently windows 7 should be covered under warranty, so when he f**ks it up he can bring it back for me to spend 5 hours fixing and he won't have to pay anything for it. So I put the question to him, if I got him to build me a house and then I knocked a wall down inside it and the house falls down would he have to build it up for me again?
Ah but then if it could be ascertained that the one leg is both the same and the impartial judges ruled in favour then it could be established that X > Green > *. Correct?
I concur. I believe we should organise a committee to proceed with aforementioned investigations.
Finding impartial judges is like f**king for virginity. :action-smiley-069:
http://www.youtube.com/watch?v=7ya-v-jchr0
R34,33,32 review on top gear from way back. I haven't seen this before so maybe some other guys haven't either!
yes colin he did, its currently been sitting in the workshop since monday arvo though with a coolant leak from a turbo line, its almost an engine out job to replace this 4 inch length of hose!
It's not too bad, taxi spray red but generally a clean car couple minor mods here and there, although he wants these modena rims.
Also tell your dad to buy that cortina, and i'll remember to bring some empties for you tomorrow night
Happy Birthday John. Rock on I says
Cheers mangs!
Not feeling the <3 no more..... :(
And
HAPPY BIRTHDAY JOHN!!!!
if you didn't see it due to post skimming........ :action-smiley-069:
Edit: Happy Birthday John! hahaha.
:D
That's the S1 review from the silly fat fucker that Martin and I were talking about.
Not feeling the <3 no more..... :)
And
if you didn't see it due to post skimming........ :(
Didn't see it! Was skimming! Sorry
Mucho thankies and epic <3
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
