Wow everyone's birthdaying this bitch of a month up!!
P.S. Happy birthday John, Colin and Tony :(
Edited by mosquitocoils
Who wants to go out and get wrecked on saturday?
I lost my license for a DUI.
Blew 0.051 and I'm on my Ps.
For f*cks sake. I had like 2 beers.
Shouldn't you be 0.00 on P's?
What RPM are you guys doing at 100km\h in 4th gear?
:goes does skids:
not sure on 100 at 4th but mine is as follows
3000rpm in 3rd = 60
3000rpm in 4th = 80
3000rpm in 5th = 100
seems trippy.
There was always hotties in the Vet area of UQ St Lucia. Not sure about gatton though...
I was in at Vet Science today. Many a hottie
LOL! I think that just about all of those videos have been on =3 at some point
Yeah they have
My birthday today. =]
Happy birthday you daft bastard..... :D
Agreed
No idea, mine is tiptronic = lazy spec.
2 beers too many?
From memory about 3.5k in the GTR.
yeah. dont know how i did that. meant to be 0.00 but it was cold and we needed smokes.
Also, I am now working as a recruitment consultant for ABT Recruitment.
We basically specialise in dealing with Accountants working in the profession.
We are also associated with the NPA network and hence know a few other recruiters out there.
Anyone that needs a job, call me! :D
STL!
wut ? :whistling:
:goes does skids:
3000rpm in 3rd = 60
3000rpm in 4th = 80
seems trippy.
3000rpm for me is 110 in fifth :):D
Anyone that needs a job, call me! :whistling:
Do they deal with IT stuff? Cause thats me!
Happy Birthday my KFC craving, car stealing, grape drank drinking friend :whistling:
NFI what RPM I'm doing in 4th in 5th.... but mine is probably different to yours anyway, Andy. What, with my little two point oh.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
