Wow everyone's birthdaying this bitch of a month up!!
P.S. Happy birthday John, Colin and Tony :(
Edited by mosquitocoils
Who wants to go out and get wrecked on saturday?
I lost my license for a DUI.
Blew 0.051 and I'm on my Ps.
For f*cks sake. I had like 2 beers.
Shouldn't you be 0.00 on P's?
What RPM are you guys doing at 100km\h in 4th gear?
:goes does skids:
not sure on 100 at 4th but mine is as follows
3000rpm in 3rd = 60
3000rpm in 4th = 80
3000rpm in 5th = 100
seems trippy.
There was always hotties in the Vet area of UQ St Lucia. Not sure about gatton though...
I was in at Vet Science today. Many a hottie
LOL! I think that just about all of those videos have been on =3 at some point
Yeah they have
My birthday today. =]
Happy birthday you daft bastard..... :D
Agreed
No idea, mine is tiptronic = lazy spec.
2 beers too many?
From memory about 3.5k in the GTR.
yeah. dont know how i did that. meant to be 0.00 but it was cold and we needed smokes.
Also, I am now working as a recruitment consultant for ABT Recruitment.
We basically specialise in dealing with Accountants working in the profession.
We are also associated with the NPA network and hence know a few other recruiters out there.
Anyone that needs a job, call me! :D
STL!
wut ? :whistling:
:goes does skids:
3000rpm in 3rd = 60
3000rpm in 4th = 80
seems trippy.
3000rpm for me is 110 in fifth :):D
Anyone that needs a job, call me! :whistling:
Do they deal with IT stuff? Cause thats me!
Happy Birthday my KFC craving, car stealing, grape drank drinking friend :whistling:
NFI what RPM I'm doing in 4th in 5th.... but mine is probably different to yours anyway, Andy. What, with my little two point oh.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
