oh, we're not going to get into that argument again are we?
speed = rpm x gear ratio x diff ratio x circumference of wheel.
Engine size is irrellevant (unless a different diff ratio is driven by the engine size)
You should know that, what with your cert 2 in mechanicalisation and all :whistling:
P.S. Do you have DS9 or NG?
was wondering if you'd pick up on that :whistling: thought that thread might have been a bit old
Don't have either B-ro.
thanks for the info kids! Was trying to compare some dyno sheets, it confirms my assumptions!
car to elaborate. i love assumptions. i assume a whole lot of crap each day. i have to. i live near inala
my assumption off the top of my head was that i was doing 80 at 2800 rpm and that each 400 rpm = 10km/hour
Im doing it to compare my hp vs speed dyno graph to another guys kw vs rpm graph, I had it all finished then i forgot to save it.
Do they deal with IT stuff? Cause thats me!
We have associates that deal with IT.
I shall pm you my work number and we can go from there.
How is everyone?
    • Yes. Get rid of that battery. It is dead. It will cause problems.
    • Don't assume too much when there is a voltage issue....if the battery is flat and the alternator not charging it is easy for the voltage to drop way low at the ECU due to the draw of stuff like coils, fuel pump etc Whatever you see at the battery with the motor off, it should be at least 13.8 with it running
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
