The mission, to boldy cook where no one has cooked before (at least at my work anyway)
Two pork chops in the sandwich toaster
Almost cooked
Let the munching commence
...tomato sauce on pork?
...what a waste of pork... :)
it was but i felt like some tomato and thats all there was at work
points for rad cooking exercise though :)
cheers. i'll try something different tomorrow too :down:
2:45
had to microwave the vegies which took 2:45 but i had the sandwich toaster on for a few mins before so it was up to "toasting" temp.
I just fitted some of those Bosch plugs noel was talking about, will find out tomorrow night if they are any good, its minor upgrade time on the old GTS
I used the sandwich toaster to do hash browns before at the office...
Works great on "contact grill" setting... took about 4 minutes from frozen solid...
...what a waste of pork... :D
That's what she said
lol I need to do this at work. How long did it take to cook?
I also need to do this at work!
Pretty quiet in here over the weekend.
Had an interesting day, woke up at 6 this morning to police banging on the door. Turns out my mate dropped the clutch down a street in albany creek so now his car is sitting at an impound lot. Was funny but still, f**k loosing your car for 2 days plus the likely loss of license.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
