Clearly you've got the rule wrong.
I always thought it was: A TV should not have more cars than wheels.
Which would generally hold true.
Morning all!
That chick in the second pic (all on her lonesome) Is 100% Andy approved the only thing she needs for a pefect Andy score is longer hair :cool:
I like boobs.
Buck's weekends are awesome.
Who else got completely useless-ified after paint ball on Sat? I sure as hell know I did. I spent all of yesterday with one hell of a monster hang over....
it all went down hill quickly after the 2 rum shots, 2 blue curacao, 1 beer bong followed by another blue curacao shot within a minute..... 'okay guys, I'm ready! LEts get goionhg to threw shitty wer ewewkjnwqnj........ BEER!'
How is 100% not a perfect score?
I like boobs.
+1
+1
+0
ewewkjnwqnj yourself
sounds like a 100% Andy approved weekend plan, needed more skids though.
I think you throw that 100% around a bit too much...
107% is the new 100% obviously. Weekend = got drunk and took the wheels off tristans car for the luls. Epic luls ensued.
I can 100% approve of somthing with out it being perfect you see
Examples: I approve of Colin....but he is a ranga, so as such he is not perfect. I approve of Martin but he owns a R31 and an Alpha so is not perfect
Morn.
What's everyone up to today apart from working?
It's my day off and I just had an army of bagpipe playing, snare drum hitting scottish people somewhere near me. And just when you thought it had stopped, it starts again.
+1 headache.
So true. I've scouted SD but couldn't find the pics yet :thumbsup:
Ahh, thanks for the clarification.
Although FYI, I AM perfect ;)
Morn.
+1 headache.
Looking at expensive parts I shouldn't buy for my bike.
And avoiding doing work... I think I have the worst 2.5 weeks work to do in history :P
call me picky... but the chick in #2 has some muffin-top going on....
picky
2004 kona caldera, pretty much like this one:
http://www.nwsporting.com/images/clip_image004_0000.jpg
Needs new wheels, and lots of TLC.
I don't think the downhill the terrorist does is all that epic, but yeah i'll give it a crack.
Probably needs bigger brakes for downhill though, thats one of the things i've been looking at... but will probably at least give the ones on it a go and see how good they are.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
