Morning Mangs,
Martin's school of fixing sh*t, lesson 1:
1. unplug everything.
2. Spray with contact cleaner.
3. Plug everything back in.
4. ???
5. Profit.
The above technique applies to many things: cars, computers, plasma TVs, etc.
Stomped hard on the brakes lots on the way to work, car doesnt seem to be cutting out any more. Also my speedo seems to have come good as well :/.
fark i hate mondays.
how was sundays racing?
Meh, broke sh*t, didn't get many laps in, and got sunburnt. Sh*t happens.
haha nice mang. What do you normally run around there?
64.3ish is my best. I'm sure the car is capable of more, I just haven't been able to string a lap together. This year in particular seems to be conspiring against me.
Stomped hard on the brakes lots on the way to work, car doesnt seem to be cutting out any more. Also my speedo seems to have come good as well :).
win
Way more awesome than that is that I did 7 laps, and came 31st overall :blink::P;)
more win
double post win?
double post lose
Anyone notice the severe thunderstorm and hail warning?
pfft, just drove home throught it, its a pissweak storm.
win
more win
i think they are ignoring you....
seems to have passed though just light rain here
:blink: to all :P
Howdy partners..
Yes I noticed the thunderstorm warning, not a concern for me, being that i'm in Townsville.
McFly, much awesomeness.
anyone know the diameter of 32 GTR standard front pipes? Guy is selling a set on her for $150 but they are twin 63mm pipes into a 75mm collector. Just wondering whether it's worth the trouble. Still $150 is not bad. I think the HKS ones are 70mm to 80 or 85mm collector.
was pretty heavy at 3. I could see about 4 feet.
didn't even know there was a storm. spent all day in the office. was kinda surprised when i saw it was wet outside when i finished at 5
2.5inch twins into 2.95inch
VS.
2.75inch twins into 3.15inch (or 3.35inch)
Consider that they need to flow enough for 1.3ltrs each. Or to break it down further, only enough power for up to 150kw each. Easily doable with 2.5" crush bent exhaust, I made 170kw atw in my old 626 wagon with 2.5" crush bent system.
What size cat and exhaust are you running? 3"?
VS.
Compliance cat and 3inch catback. I think I'll grab em. Low ball ftw.
Morning Mangs,
Futsal was a great success even though we lost :wub: Tristan and Dan dogged us so we only had 5 players. We ended up losing 8 - 7 but it could of gone either way at the end. I scored 4 :)
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
