I dunno the new mega mac is pretty good. Morning Mangs.
Mega Mac is great, needs an extra shot of mac sauce definately.
Any of you Mangs know how much of a dick around it is to become a member >?
Those shirts are cool.
You're a quiet bunch of mangs today :P
Trying to get enough work done so that I can go home early without walking gant chart man harrassing me.
I do not know how much of a dick around it is. However, you don't need to become a member to buy the shirts :(
Needs better wheels
I accidentally my pants. :)
That's what she said
^ I accidentally my pants. :(
im here to please
Needs better wheels
avs5 are a classic jap wheel - i thought you of all ppl would appreciate mr advan :)
ps ive looked high and low, i cant find any pics of you from the weekend :P
im here to please
That's what she said.
This may be true, but they don't suit that car tractor at all :(
Probably isn't many, spent much of the day in the pits :(. I haven't checked out boost but here are a couple from Chris:
http://www.sauqld.com/ipb/index.php?act=at...ost&id=5776
http://www.sauqld.com/ipb/index.php?act=at...ost&id=5799
And from Brendon on the 31 club (I haven't actually watched the video but apparantly it is from when it was broken so very slow):
Seen it. It's pretty good. Barbara is less of a useless bitch.
I just lol'd at that description
McFly, due to your epic tower buzzing speeds, this is the only pic that turned out, sorry:
Oh yeah, just about breaking the sound barrier past the tower :(
Afternoon all,
TGIF.
That and the fact that it's the boss's bday so we've spent most of the day at the Pig N Whistle.
Ahh, the weekend shall be good.
I'm defs coming to BnR next weekend.
That is all. :):D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
