If anyone is looking for work I recommend asking Tony or Hays Recruitment. Tony put me onto these guys, signed up yesterday applied for a few jobs and got a call first thing this morning. Oh well fingers crossed. Downside is working in the city although that means less petrol, less k's on the coon and more money towards the next car.
Evening chaps
Anyone know much about hubs? Specifically I have to replace some wheel studs on my rear left wheel (33 GTST), the sucker won't move (much like when Dan came and helped with the Laser :P ) and I've thrown everything I can at it...breaker bars, impact wrench, air ratchet... nothing.
Which way should it be turned? Clockwise or anticlockwise? I've been trying both in spurts but I'd like to be sure of one direction and just smash all my weight into it
Congratz mate!
Great to hear that Hays was able to help you out.
If anyone did want to see if I could pull a few strings to get them something then just PM me.
Keaton should have my email as well, so you could just grab it off him if he doesn't mind. :P
Was it a temp or perm role?
Congratz again!!
Nice score col. Now hurry up and buy a GTS-R and sell me the exhaust manifold and heatsheild from the RB20DET-R
Currentyl considering buying an GTS-X with a RB20DET-R in it.... tis a fine looking machine.
Evening chaps
Anyone know much about hubs? Specifically I have to replace some wheel studs on my rear left wheel (33 GTST), the sucker won't move (much like when Dan came and helped with the Laser :( ) and I've thrown everything I can at it...breaker bars, impact wrench, air ratchet... nothing.
Have you tried kicking it ?
Evening chaps
Anyone know much about hubs? Specifically I have to replace some wheel studs on my rear left wheel (33 GTST), the sucker won't move (much like when Dan came and helped with the Laser :) ) and I've thrown everything I can at it...breaker bars, impact wrench, air ratchet... nothing.
Hey guys, whats been happening?
Mate the wheel studs are a press fit so you need to push them out not twist them. Have seen it done with a hammer but this isn't the best way because the hits also smash the axle bearing and can cause it to get flat spots on the rollers leading to failure. If your going to do it this way then you should put a nut just on the stud to stop it from mushrooming. The other way you can do it is to use a ball joint remover although have never used one for this. Acording to the manual you can't remove the hub. Unsure as to why but. To reinstall space it out with washers and tighten with a nut to pull it back in. You'll have to remove the disk and pads to do this as well.
Hope this helps mate
By the way has anyone seen a 32 gtr box forsale around in brissy? Mine split a seal and dumped all the oil and now i've lost 4th syncro and probably cooked it :( Just after a secondhand one at the moment. Pm if you know where one is thanks :)
Cheers Matt
Reel big fish?
are awesome
side note am going to attempt this ;
iCrap 3000
should result in possible awesomeness or epic failure hopefully with lots of fire. Either way
win :(
are awesome
iCrap 3000
win :(
Lol i just opened that up and got no idea what that means or what it gives you. Mind you I'm just a mechanic so not really good at that stuff :)
are awesome
iCrap 3000
win :(
I approve of this plan as it will hopefully result in one less iPhail in the world :)
are awesome
iCrap 3000
win :(
This should be interesting.
My iPhone has turned to crap after the OS update.
Well, crap turning into crapper crap. Does a double negative make a positive?
In this case no
    • Yep, cheapest options, neglected and abused. The fastest way to dislike a car is to get assigned that model by a budget rental company
    • The noise complaint could be from absolutely anywhere, and anyone. Get it actually noise level tested to find out if you're actually over, or if you're fine. If you're over, quieten it down. If you're under, carry the test results in the car with you.
    • SAU NSW x Benzin Cafe Cars & Coffee Sunday 12th October 2025 7:30AM Meeting Benzin Cafe Meet Location: Benzin Cafe Dural RSVP: https://forms.gle/Q9TcFu9DHe4dbvtKA   *Disclaimer* One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Is it your wedding? If not, no real need to be there...
    • Soz Duncan, I have to head up the central coast on that Friday, I have a Wedding on Sat morning.
