live timing works for me!
after 20ish min there's a full track yellow. Hitler youth is running fastest. Hamilton is in second, but it looks like he might have just had a crash. Mr Webber is in 4th
also, the slip light is good now... car just needed turning off
Thanks!
I've now haxed it :ermm:
Lol @ hamburger
Ranga+Ravi: congrats on the BDO tickets! I decided not to go this time around =/
Fail... it's actually gonna rock my socks off
oh ravbat, your 33 still for sale? my work mate will be looking for a 33 soon, so i'll point him in your direction
It is... just gotta fix these damn studs that I'm not manly enough to bash out... the suckers are pretty much rusted to the hub. Anyway, after that all that's left is brake pads and fluid change and I'll be happy to let her go.
By all means, please point him my way. Might be keen for swaps + cash my way too. Or a slab of VB.
f**k sorry, my boostcruise-itis got out again
Morning Mangs,
TFIF shit day today.
Quoted for brutal truth
In other news, I think I've decided to pick up a cheapish R32 after the 33's gone. Or even swap + cash my way... it's mainly a financial thing at this point for me, and the laser gets me to and from work ok so I can spend the next couple of months pussying around and (hopefully) modding the 32 up, til I have all my points back bahahaha
*stamp* APPROVED
OR: Buy my 31 ute.
whats the price difference between a R33 and a R32 nowdays? I know I sold my R33 for 5k and a hug, surely a R32 isnt any cheaper?! lol
John: glorious win on the Grace approval... but you're hiding your wall posts?
As McFly said, that's on Baskin's wall. I turned my wall off aaages ago. Facebook keep changing their settings for what will and what won't publish. All I wanted on my wall was my wall posts, and nothing else. It started putting EVERYTHING up there, and it took way too long to delete all the other posts and make it tidy, especially with posts from games and apps and such. So I just turned the whole damn lot off. Much easier :ermm:
Edited by Isola
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
