Finally some clear weather, so got the skyline out instead of the vw.
Driving the skyline in the wet is a major pain in the ass, as the demisters are rubbish and there is no air con, so usually have to drive with the window open, getting rained on...
And that's winthout mentioning the $80 a pop, plastic rear, barely can be called, tyres
Edited by PWND
My windscreen wiper has an issue where it sometimes scrapes the windscreen, quite annoying when you're sitting in traffic, you're ipod is dead, no good cds in the car and all you can hear is metal scraping glass.
My drivers side window also doesn't go up which is awesome for surprise storms.
Don't get me started about driving in the rain lol. The 31 has no heater or A/C and 1 window is never enough to stop the windscreen from fogging up so I end up with all the windows open. My lights are shithouse normally add rain into the mix and I can see about a metre infront of the car for everything else I have to use the force. Can't see out of the back window because of shit tint left over. The wipers are f**ked and seem to readjust whenever they please so one minute they will be fine next they won't make it over to the drivers side or they overshoot it and go off the windscreen entirely.
Certainly makes driving in the rain an adventure...
My 31 is just as pleasant to drive in the rain as it is in the dry
My 32 is good too. Just not when I have to cross epic rivers. The air con demists the rear window, so it doesn't matter that the rear demister doesn't work :banana:
Lol, what an evening. Was feeling energetic this afternoon and decided to tape up the coil packs on the 33, it had a flat battery as well so I went and picked up some jumper cables from a mate and jump started the car. Went out for a drive up to the servo in warner/bray park to pump tyres up. Car just started after putting some petrol in, gave it a bit of a boot to see how the coil packs went now that we'd fixed them up, was all sunshine and roses. Until the car started hunting.
Someone forgot to tighten a hose clamp up.
Had no flat head screwdriver so we called home and got someone to bring my car out, got the car and fixed up the hose clamp. Now my bonnet doesn't open so we were trying to flag down a car. A black 32 drove past us, kept going, a multitude of other cars as well as a white stagea who did a skid around the roundabout and then got chased by an undercover car. So thanks to those two drivers for pulling over! lol. In the end a hot little p plater pulled over and we got it all going :banana:
*Stamp* APPROVED
Got this link in a email from Dad this morning lol. As good as the learn to speak Jap chick for sure.
*Stamp* APPROVED
learn to speak jap chick has nudes thus = better
I could only find shit pics that may or may not be her. I fail at internets. I demand that you share!
Question of the day - if you could swap your car for anything within reason (say 20k+ the value of your current vehicle) what would it be?
Mine? A very clean 32 GTR or 34 GTR.
My car with +20k spent on engine mods
In order of preference:
240Z fully restored + turbo L28 conversion
32GTR with a lot of work done
350Z + turbo conversion
Z32 2+0 twin turbo targa top
S2000
Bongo van
S2000
you beat me to it John
Mine is 240z, with either a rb26 or similar.
Currently in the market for a reasonable 240z shell :banana:
im actually the same as Martin, I would like another 20k to sink into mine for brakes, new suspension, track rubber, carbon bits and maybe some bigger turbos :banana:
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
