Mangs. See you all this afternoon.
On a side note, what's everyone's thoughts on monza bucket seats.
Option 1 have an ADR compliant fixed back one that I am considering instead of velo.
Comments, thoughts, insults?
Comments?
Monza stuff seems to be getting better, although it is not as good as the more expensive stuff obviously. Seems to be quite decent and good value gear.
I'm probably going to get Monza harnesses for the alfa.
thoughts?
Thinking has been suspended for the remainder of the day, and most likely for the remainder of the week as well.
insults?
You're a useless serb.
Think about it mate. i will be there in alvin. she'll go farken nutz tryin to get at me.
It's not rape if she's begging for it :P
Only comment is that a fixed back in a 2 dorr is illegal regardless of ADR, If you are cool with that I say why not!
Yeh, as Col said, going the 2 seat route anyway, so will be getting it mod plated and registered as a 2 seater. Going one fixed back drivers seat and one gtr seat, with kind thanks to Noel, so I can still have easy access to the back area without having to remove a seat.
I popped in today and had a look at it. Looks good. ADR approval on it, and most impotantly, I fit in it, unlike Bride and most Sparco seats.
Link for any other people interested or that want to have a look:
http://www.boostcruising.com/forums/index....howtopic=641160
They are out of stock till November though
Speaking of which, i should have my car back this weekend Miso, should be able to hook you up any time there after.
As for the monza, TJ33 has one in brand new condition, I sat in it the other night and was very surprised at how comfy and supportive it was. Its for sale pretty cheap too. Silver in colour. different but nice.
All of those seats look pretty good!
Too easy, cheers.
TJ33, is he a member on here, with that nick? might pm him and have a look at it.
lol, i got some issue in my car, thinking its a blocked fuel filter. Car just has a sluggish pickup under load...
meh, i'll change it on saturday while i drink
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
