in for pg 700.
*1400
Now taking guesses as to how unfit I am. In between this post:
F*ck door trims.
For a show and shine winner, my car is an utter shitbox :(
And this post:
</3
I went for a 20min ride, and am completely f*cked. How far do you think I went?
Winner will receive 1 broken door trim clip, and possibly some abuse.
Edited by Smity42
*treading carefully*
10k's?
20 minutes, you probably rode to the park near the paper mill.
Anna its your fault he won.
Martin i can repair this door card.
10k's?
You sir, give me too much credit.
And you don't give me enough :(
Truth.
I'll hold you to that.
Passenger side I think is just about sussed. Doesn't seem to clip perfectly in the corner but its pretty good.
Driver's side I'm waiting for glue to dry on the two mounts I crimmed from my new spare trims. Will see how it holds up after that...
Morning Mangs,
How do you do skids in a boat? :D
Jokes mang, congrats.
should try owning a stagea if you think an r33 is a boat :)
2T with fuel and driver .. even boats arent that heavy :)
Edited by PetroDola
Morning Mangs,
Driver's side door trim is now holding on about as good as the passenger one. Not perfect, but at least the trims don't fall off as you open the door any more :).
that is all
:D
That's what she said.
Holy mother of god!
should try owning a stagea if you think an r33 is a boat ;)
My coon weighs a slightly less than that. Want to trade? ;)
10k's?
No Dice, Too high.
= ~3km round trip. No Dice, Too low.
3.6km Martin.
Still too low. Just think how far I could have gone if you hadn't run me down and busted my knee...
Supercheap... or the equivalent distance in any other direction.
Assuming you mean super cheap at lawnton... = 6.0km round trip. Oh my, this is going down to the wire...
6.3km
6.31km
I needed to refer to the cyclocomputer to resolve this one, I knew it was 6km but going to two decimal places, sheesh!
and the winner is...
6.08km!!!!!! It's JOHN!!!!!!!
Congratulations, you useless dole bludging bastard (right, thats the abuse coverred). You may collect your broken door trim clip tonight.
Edited by Smity42
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
