Not really, we talked about mats, spoilers, double posts and drunk chicks. All in all a successful day if you ask me
You guys moved the thread two pages... yet manage to say nothing...
So what? You and Jason used to move it about 20 pages overnight and say nothing.
This.
You know, that was probably more than I did at work all day.
i spent 5 hours removing the heads from a blown engine, $11,850 job in total, only $2500 of that is the parts, rest is labour. all because he didnt want to spend $1800 last time to get the cambelt replaced.
So the drunk chick was silent :P
Not following?
I didn't realise the Top Gear Live show's had other shit in them. I just assumed you paid money to stand around, watch some videos and see people talk. Could be kinda cool though.
Who's up for top gear live?
http://www.topgearlive.com.au/brisbane
I'm thinking Platinum tickets ($130)
Keen when are tickets on sale?
Not following?
no its not the live studio audience, its a live stage show
went to the one in syd a couple of years ago, it was pretty cool
now brah
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
