Morning guys....... anyone follow Hamish and Andy? I missed the tv special on Sunday night, and managed to find a torrent for it, if anyone wants it.
awesome photo today colin. Really wish i could be cruising the gold coast....
:D
WTF? Msn has vanished and I can't get it back :blush:
You never reply on msn anyway :D
holy thread batman
Quick Robin, get the lube :D
Morning mangs.
holy thread batman
That's what she said.
Finishing work at 6am, living the dream..... woah oh oh etc.
Night shift hey?
They seem midly amusing, but no not really.
That just isn't true, I always reply (eventually). Remember, it's not a race. At least, thats what your sister always tells me...
Morning mangs.
Morning.
I think I need to purchase some new parts for my HTPC... shame they aren't as cheap as I'd hoped :D.
What's John up to these days? Missing, presumed employed?
Anyone up for a German Club night? I need my fill of massive sausage (that's what she said)
Thristian you still owe me a mountain run
Can't do German until after I move out. Skipping everything this week to get the unit clean n ready to get out of there on Saturday. I will also be broke after moving out so yeah I dunno.
Marto agreed! We need moar mountain!
Got epic amounts of shifts at work at the mo, so no time, but plenty of fuel/tyre monies!
I'll let you know!
No marto you never reply
Lies. I reply to you and your sh*tc*nt mac just throws the messages away,
What you doing?
I'll let you know!
Ps sorry for lack of quoting ;)
I find your lack of faith quoting disturbing.
Watching the rock apes try and do tests is funny as hell. Finges moving along the page to keep their place, and 5 pittiful little voices reading aloud in a pre-school stop-start sort of way ;)
I has a rage
Annas sisters wedding ended up costing us around $850 because of how much driving we had to do, how expensive Annas Bridesmaids dress was and all the other associated incidental shit. It also cost me 3 days of my leave, and rather than having time off i worked harder than i would at work. So now i have no leave and am broke for the weekend, f**k you weddings, f**k you.
End vent/
I has a rage
End vent/
I feel joor pain. Weddings suck ;)
Hey Minges. I am also Le' Tired...
Currently in Townsville waiting for my flight to Cairns. Been up since 4.30 this morning and wont get to Cairns until after 8.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
