And they're off. Hopefully at least Watto is still in by the time I get to the GABBA this arvo
katich out
batting collapse incoming
You will now not post for the rest of the day
@Colon: Got a guy who may be interested in your serty-wan. OK if I give him your mobile/email/something?
Yeah man give him my details n tell him to give us a yell. :ermm:
afternoon was shaping up to be awesome until 4:30 when they stopped playing. I blame haddin entirely, he's a skirt. The Hussmeister would have kept batting all night if they'd let him.
4:30, bit early for dinner I thought, but hey, what the hell. Then I get out of the stadium and it is PISSING down rain. Absolutely soaked by the time I get across the road into the german club. THEN they aren't even serving food! Kitchen to open at 5:30. f**k that. Then have to walk to my car in the rain, then have to fight traffic home.
Massive lose :ermm:
Oil +Filter change on the pintara, fixed the hand brake and installed a new pod filter on the beastly ca20e
Ready for a roadworthy i think ;)
O and drifteks dont fit on it :( worth a try i thought :)
I get my cage tomorrow morning. Yay
Might have to wait till next weekend to fit it tho. Don't have any tools, and will be learning as I go.
I'm sure if you put the word out some tools would turn up with a spanner or two. ;)
There's not a huge ammount of space at my place, so I usually don't bother doing that much plus don't have tools at home, and can't do it this weekend as I am flat out, ish
Next weekend will go out to a cousins place and have a crack. He's the one that owns the pig farm. Will try to score some salami.... and that's not what she said
fuckers...
well that was a day at the cricket
got well drunk, then very wet on the way into town
stopped at the chalk for a beer while it was raining only to find two naked chicks being painted with body paint
was a win win win
pics or it didn't happen
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
