Wooho, they are finally getting scoresheets and individual stats etc online for indoor!
Last night I got 17 (7 balls) and 1/12. Officially putting my hand up for Marcus North's spot :P.
He'd have had them all out by drinks most matches...
now thats just wearing rose titned glasses if i ever saw it! He is good, but no one is that good!
but it isnt real cricket? Its like the drifting of cricket
in that case we should have had every team out in half a session in every game? And even in games where he didnt open the bowling the innings would have ended in half a session after he came on to bowl? NO WONDER WE HAD SUCH A GOOD RECORD!!!!! lol
Just looked at Adelaides weather yesterday...massive batting collapse causing us to lose the test by 11:37....Giant downpour at 2:09 that did not stop all night....BAH
g'day, scarnon?
Working from home allows me to lurk :)
Not sure if I'll make it to a Thursday night meet before Christmas at this rate. =/ Always seem to be doing something with the gf on thurs nights these days.
Haven't seen it. Cliffnotes?
Three dudes beat a stranger/homeless dude? lying on the ground, in the face with a hammer
Then they stab him repeatedly, first in the torso then in the face.
The guy stays alive for all of it, before he is finally bludgeoned to death at the end.
The three perpetrators are laughing during most of it.
I watched the first thirty secs, when the guy was smashing him with a hammer. Could not watch the rest.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
