When replacing my turbo, what gaskets do I need?
I'm thinking:
Manifold-> turbo gasket
Turbo->dump gasket
Oil return gasket?
Am I right that the oil feed doesn't need one?
Turbo->dump gasket
These. Althought they are fairly sturdy gaskets and if they are in good nick you might be able to re-use your current ones.
Oil return gasket?
Should just be able to remove the oil return hose so shouldn't need a new gasket here.
You should replace all the banjo bolt washers on the oil feed/water feed/water return. That said, a lot of people probably don't bother, but they are not very expensive so I would.
Just take the banjo bolts to enzed or something and ask for banjo washers to suit.
What exactly IS a banjo bolt?
There will be one on each end of you oil feed line, water feed line, and water return line. So 6 banjo fittings, needing a total of 12 washers. The sizes will vary, (some will be the same some different) so you will need to work out the sizes you need when you pull it off and then take them in and say "I need 4 of these ones, 8 of these ones..." etc.)
The oil return line is just a normal clamed hose. I can't remember 100% but I think the gasket you are talking about for that one is where the hose fitting connects to either the block or the turbo. But you don't need to undo it there, just undo one of the hose clamps and take the hose off.
EDIT: That picture is a little misleading, the washers are not actually copper washers but 'banjo washers'. According to the dude at Enzed when I went anyway...
Edited by Smity42
Ok so I -might- be able to re-use those washers, depending on how they look when they come out?
Should I drop my oil before I do this? Or will it just be a small amount of oil that comes out of the feed?
I should drop my coolant though, yes?
You are NOT supposed to re-use the washers. They crush when you tighten the bolt and that is how they seal. Once crushed you are not meant to re-use them.
I think some people do though, but its a bit dodgy, and you may end up with leaks.
It might only be 31 owners that re-use them...
Should be no need to drop the oil, just let the car sit for a while so that most of it drains back to the sump before you do it. You may spill a small amount but nothing much.
Water... Can't remember. You will probably lose a fair bit of it so put a drain tin down, but theres probably no need to drain it entirely. Just fill it back up and bleed it when you're finished.
Been shut for a while for the airport link work. Maybe it was only through certain hours...
Did not know that. Must only be certain hours...
I meant on the turbo where the oil return goes in (i think thats what it is, not sure) there's like a flat surface area around the hole - looks like it needs a gasket.
Burson have a turbo gasket kit with 2 metal gaskets and 'about' 4 cork ones for $50. No washers.
What's the enzed place you mentioned?
Edited by mosquitocoils
Ahh... if there is something there that you have to transfer from your old turbo to your new that needs a gasket, then yeah you will need that.
NFI what those cork ones would be. Pics?
2 metal ones would me manifold-turbo and turbo-dump I reckon.
enzed (http://www.enzed.com.au/) or pirtek (http://www.pirtek.com.au/) or any other hose joint really. I didn't get a mobile guy out, I just went into a store.
been up in the copper today again, brisbane is a sea of activity...
people, cars, trucks everywhere...
seems business is back to normal for the major shopping centers...
hope the people who bought 20 loaf's of bread die eating them, wankers...
Yeah I'll just suss out what I need to re-use when I get to it I guess.
Twas over the phone my good sir so no pics, but I was guessing the same as you.
So, good thing no one went to old Baskins last night...
XF and 33s would have gotten across that...
Are we allowed to pick women folk in the mens cricket team? I reckon this Elyse Perry chick bowls better than ANY of the blokes do...
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
