Morning Mangs,
Bridge @ Petrie closed again :(. Made it a hell of job to get to work.
Weekend was good. Sat morning went shopping for boots, gloves, work clothes, etc. Got a sweet bright orange shirt off the discount rack, and some second hand army boots :). Then went in and helped clean up sludge. Sun went and admired VQ35 powered R31 roar into life, then did the mowing etc. Mowing took ages and still didn't get it finished because the damn mower kept breaking :(. Then watched the cricket. OMFG won two matches in a row now!
morning ya'll
gotta drive to zillmere this morning
hopefully the traffic is not ridiculous
According to the news, CBD traffic is shit.
Nothing crazy over this side of town though
Hahaha no thanks
Anyone have ideas for how to make a pressure tester for my piping?
I'm thinking PVC end cap, drill small hole in side, insert bike tyre air screw part, seal around the edges and hook up to compressor.
Replace AFM with this item and listen for leaks in piping??
Will PVC withstand 10psi?
@Colin:
May have to wait a while to sort out that PC:
http://www.atomicmpc.com.au/News/244645,aussie-tech-retailer-umart-suffers-in-brisbane.aspx
Apparantly they are aranging suppliers to have stock sent to their Eight Mile Plains and Sunshine Coast stores, so keep an eye on the stocks for whichever one of them is closest to you.
@Ravbat:
It'll be under vacume at idle, you can spray WD40 or something similar at places that might leak (joins in pipework, etc) and the idle should pick up momentarily when the WD40 blocks the air leak. It may also buble a bit.
How were you planning to listen to it while boosting? It won't build much boost in Neutral (no load). Ignore me...
Edited by Smity42
Sarp mangs. I had a good weekend. Did pretty much f**k all. Got home from work at 2:30ish and went out and bought COD Black Ops and GT5. After that I barely moved off the couch lol. :thumbsup:
lol. GT5 = WIN!
morning ya'll
Triffic is a little bit nutty today...
Morning Mangs,
I was considering getting into the slop of it all, but we had trouble getting in. Nat went out around 4.30pm yesterday and had trouble getting anywhere near a place to help....
Nothing is too crazy over this side either :-)
Unless you want to get here from Petrie... :(
Pass.... ;-)
Hahaha no thanks
PVC will be fine with 10psi. I would suggest you get some 75mm piping and an endcap. Seal it with plumbers glue. It's not too expensive. Drill a hole in the end and tap it to suit a fitting that you can plug into that seals.
Keep in mind you should block off all rocker cover breathers, etc, as this gives the air an escape path from the piping. You may end up giving your engine an involuntary lease down.... haha
@Ravbat:
The engine's not gonna be on, just block off the throttle plate and replace AFM with tester, pump with air compressor/bike pump etc and listen for leaks.
Yeah, as above will block off throttle/intake so it doesn't even get to the motor.
Thanks for the info too man
Next question is how to block the throttle end of the piping??
@Colin:
http://www.atomicmpc...n-brisbane.aspx
@Ravbat:
Ah shit. I ordered everything from the Milton store so I'll call up the logan one today and see if they can get my order n shit.
Yeah we had to drive around for a while before we found somewhere that wasn't swamped with volunteers. Eventaully found a street in st lucia (not far from my old place) that seemed to just have the people that lived there and their friends/family, so we stopped and helped there.
Quiet weekend, tried to fall off the roof cleanig the gutters out. Gave up and started drinking instead. Does anyone have a blower/ vac I could borrow for a weekend?
Jez, I've got a blower/vac you can borrow. It has a few little puncture holes in the bag, but it still works ok.
McFly, what year Z32 ECU do you have? When do you want me to do the mods on it for you? You'll get the best results using a Z32 AFM also... They tend to run pig rich with R33 items.
I have two coming from Japland (one for me, one for the terrorist), but I don't have them yet. Both should be the 8-bit ones (for type 2 nistune board). Whenever they rock up and I confirm they are right (and confirm my consult wiring is all good etc), I'll order the nistune. Then I'll need you to mod it whenever you can fit it in with your busy schedule... :).
Yeah I have a Z32 AFM and plug on the way as well. Im also looking at possibly getting injectors, fuel pump, and coil packs so I only need to pay for a tune once... but we'll see.
Timeframe will probably mostly depend on how badly post is affected by all the floods...
YAY!!! nistune !!!!
GTS is coming apart today for the week, time for epic rust removal so i can put the carpet back into my car without it getting wet everytime i drive it in the rain or park it not undercover
Excellent. How long do you think until you'll have it? I can mod it to run your car without throwing codes etc. You'll be able to drive around with it, no probs. Once you get the nistune board, I can solder that up for you too.
YAY!!! nistune !!!!
Yay for non-wet-feet.
Cool cool :)
How long? Under normal circumstances I would say probably early next week, perhaps even late this week. But who knows how the postal routes have been affected? I still havent got my CONSULT cable, it may well be a flood casualty for all I know or it could be sitting at an aus post depot somewhere waiting for the trucks to be able to get through...
Back from not being flooded in. Yay.
Found this in my letter box.
I asked is the reason WHY they are unmarked because they will cause iradict driving due to heavy braking and possibly causing accidents in the tunnel.
Not that it really matters since no one uses the tunnel anyways.
img-1171225-0001.pdf
Hey Jason,
Good to see you survived floodagaddon. I was worried you might be a floodzombie untill I saw you posting on faceparty.
I found an email from you in my hotmail yesterday, the one you sent before the floods with the epic rain forecast. I should have read it back then :P
Hooray for not being flooderized!
It's good to see that they actually took the time to reply to your letter.
I use the tunnels. It cuts 10mins off for me and work pays for my tolls, so why wouldn't I? It's easy enough to spot the cameras though.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
