I've run out of crayon's though.
Nikko pen will be acceptable
Jason you keen for German club?
Suspended in my work = sacked lol.
What time?
sacked,suspended, given the arse and getting a DCM all the same thing.
yer suspended at my work normally means escorted off the premises, they know we have sticky fingers and will take anything even if its bolted down
Although the word mistake at my work can range a fair bit, anywhere from a talk from the manager to a court case for manslaughter
I have a lot of colour pencils. The project manager saw me marking up scaffold drawings in coloured pencil and he was like
PM: Are you marking up drawings in coloured pencils?
Me: Hell yes
PM: You do your planning in coloured pencils?
Me: Hell yes
PM: f**k yeah I love coloured pencils.
Me: Hell yes
Me: Hell yes
Lol
and, anybody got an angle grinder I can use, or that can do a slight trim on couple of choice metal bits on my car.
cage is being a real pain in the ass to install
one long pain in the ass
jason i think what you are looking for is called "bailey channel" Im not 100% on this but pretty sure its near enough for someone to know what your talking about
I has angle grinders
you coming to german club tonight, and if so, are you going past your place first?
I just have one support bit where the sunroof used to sit fouling against the cage, so just need to trim it by about 5mm
Had a morning tea this morning to raise funds for the qld flood appeal. Everything that got donated Brookfield is going to match. So far from the head office sites in Brisbane we've raised nearly 13 grand. Solid effort by everyone :cheers:
Or, I can swing past your place at some point in the week and you can have a crack, as I haven't used an angle grinder before....
I am, and I am home now. Can bring it if you want. Angle grinder on the train will be baller. Just let me know coz I don't want to bring it if you don't want it.
If you like, although I can take no responsibility for unwanted metal damage...
Awesome stuff. Powerlink is also matching donations dollar for dollar. Was just over 20g this morning.
also keep genitals away from the spinning bit too
Since when are genitals not body parts?
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
