It sure is. I'm running the show today :whistling:
Oh btw I pressurised my intake piping last night, all my clamps etc were fine. The only thing I found was the line going to my boost gauge seems to be leaking. I unhooked it from the plenum and did it again, the only sound was now coming from that hookup at the back of the plenum. So some more vacuum hose on the way home from work this arvo and we'll see how she goes tonight.
Could that really be causing a few psi to leak though?
That's what happen to my car on the weekend, had no boost at all via the gauge, but car was fine, new hose and she's sweet. I suppose every little bit helps.
I have a leak somewhere too! Was driving along the other night and gave it its first real bootful for a few weeks and as it came on boost it sounded like a stock RB25 turbo (Ie Vaccume cleaner) and was slow as hell, Drives fine normally but so im gussing a split some where that blows open under high pressure then seals up ok at low pressure.
It could certainly make you guage read many PSI lower.
Would also potentially affect how the car runs. Anything with an AFM (ie skylines) will be particularly sensitive to boost/vac leaks.
Oh and screw black ops, get this into ya
Nice.
I removed my AFM and replaced it with a full baked bean can (clamp it in tight)
Then I pulled the cooler piping -> actuator vacuum hose and replaced it (on the piping nipple) with a bike tyre valve on a piece of hose and all clamped tight, then hooked that up the my compressor set @ 10psi.
Worked a treat, cost me $7 hahaha.
Oh, plus the baked beans. But now I'm gonna have them for lunch so it's win-win!
Edited by mosquitocoils
Tas called me last night and wanted to catch up. So i said yeah meet me near my place. So I walk down to the car park and there he is standing next to a black guy. I'm like its midnight, abandoned carpark with an asian and a black guy. Yep totally legit. Then after a bit 3 cop cars come out of nowhere arrest some drunk guy down the street. Then keep doing circles around the block obviously looking for some other guy but oddly enough driving past us (the legit guys) very slowly. Fun times.
P.s. The black guy was Shan and yes he is very black.
The end.
LOL having an accidental strayan day today. Strayan days so awesome.
The end.
Ahahaha Shan, the darkness.
Accidental Strayan Day FTW.
What did you get defected for?
AHAHAHAHA! F*ck I laughed at that. You should definitely own a 31 bro.
HAHAHA yeah I thought it was a great idea... I actually got it off this very site...
Is this the same old one? Or a NEW defect??
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
