Morning Mangs,
Site managers first day on holidays so I've spent the first 2 hours photoshopping random pictures for the site foreman lol. I should probably do some work though...maybe.
Morning Fellows! Hows it all going? Hopefully chucking the new brakes on my car on Saturday or Sunday, been ages since i have done any spanner work. Looking forward to it! Even if it is an easy job lol
Mangs,
Sitting at Motor One waiting for them to tint a craptiva. It's a good break from how busy it's been today + the heat :thumbsup:
*waves out the window at Dan*
Well dont we have a cushy job :rolleyes:
I do
I rekon i do to as am at work and bored so reading SAU. And my boss doesnt give a f today either so great day.
So... anyone want to buy a new car :whistling:
Mangs
Playing COD
Busy day, so will get back to it.
As you were
WTF I pressurised my intake system again... all my piping seems fine. It seems like there's an air leak somewhere around the rear of the motor, on the turbo side, kind of around the back corner of the rocker cover. One of the screws there was half a turn loose so tightened that but realllllllly doubt that was the problem. I already packed up the compressor etc so I didn't check again but I doubt it did anything.
What other pipes run around the back of the motor that carry pressurised intake air??
Anyone have any opinions on this?
Yes I do
But I am looking at a BMW 535i, So if you have one of those it would be great!
Yes I do
well if you look at the cars i sell front on and they are in silhoutte then we would be close
It's F*cked.
:P
Sorry, pretty hard to have a guess at what's wrong over the interwebs.
The only hose that carries air towards the back of the motor should be the feed for the idle control motor... can't remember if this is pressurised or not, I think it comes of the J pipe though so I would guess yes.
My money is still on exhaust leak before the turbo or wastegate stuck open.
Andy,
Our garage is empty enough now, if you want to start to use your garage for your car instead of storage.
Andy,
Cool, You around on saturday? Might get it towed then? PM me your adress and I will start ringing towies!
I thought wastegate stuck open as well. But then again I don't have a big idea of this sorta thing.
Just realised new sau layout is mobile friendly. Yay.
Tappet cover gaskets will leak like a bitch when thos screws get loose (Which they always are) Tighten all the screws and go from there. My R33 has lots of leaks from that area and when i fixed it all up the car was much better behaved, Of course your gasket may be rooted too but try tightening everything first
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
