Smity42 Posted January 27, 2011 Share Posted January 27, 2011 Morning Mangs, TFIF. Wonder if I can get away with an 8 hour day today? For Scott: Z32_ECU_Modifications_Direct_R33_Plugin V6.pdf. Booyah, V6. Please don't use the V3 one to do mine . Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5644690 Share on other sites More sharing options...
hylian Posted January 27, 2011 Share Posted January 27, 2011 Morn. Stuck on a train. Plus side it's fark yeah Friday. Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5644701 Share on other sites More sharing options...
Kiwibob Posted January 27, 2011 Share Posted January 27, 2011 just keep a pair of baby socks in the car, fits perfectly over the gear knob and either stops it from getting hot in first place if you remember to put it on when parking, or protects your hand after the fact if you forget. Hmmm i wonder what people would think if they walked past my car and saw my knob covered by a baby sock lol. Very good idea but i think changing knob would be better as i never did like the one i got. Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5644759 Share on other sites More sharing options...
mosquitocoils Posted January 27, 2011 Share Posted January 27, 2011 So I unhooked my wastegate actuator hose before work, went for a drive around to warm up (then a bit longer lol) Anyway, hit around 10-12psi a few times (before backing off), but laggy, and can still hear a balloon squeak type noise. Dump pipe on incorrectly? Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5644772 Share on other sites More sharing options...
Traditimeour Posted January 27, 2011 Share Posted January 27, 2011 Are you running stock dump? Manifold? Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5644848 Share on other sites More sharing options...
mosquitocoils Posted January 28, 2011 Share Posted January 28, 2011 Stock manifold (untouched when I replaced the turbo) It's a split dump/front pipe, but not one of the shitty JJR ones, it's got a huge long split for the wastegate gasses. I also checked when I had it disconnected that the wastegate flapper doesn't catch on the interior of the dump (like on the JJR ones)... but that may have changed when I put it all back together..... I'm thinking maybe the gasket could be sitting shitty or something? The wastegate is completely shut at idle. Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5644860 Share on other sites More sharing options...
Bunta Posted January 28, 2011 Share Posted January 28, 2011 So I unhooked my wastegate actuator hose before work, went for a drive around to warm up (then a bit longer lol) Anyway, hit around 10-12psi a few times (before backing off), but laggy, and can still hear a balloon squeak type noise. Dump pipe on incorrectly? so refresh my memory you are getting no boost when everything is hooked up, but when you unhook the feed to the actuator you can get boost? Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5644863 Share on other sites More sharing options...
Smity42 Posted January 28, 2011 Share Posted January 28, 2011 Damnit, Nistune only posted this morning, won't get it till Monday now . Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5644904 Share on other sites More sharing options...
mosquitocoils Posted January 28, 2011 Share Posted January 28, 2011 Correct... Although I can still hear a squealing leak under boost Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5644984 Share on other sites More sharing options...
mosquitocoils Posted January 28, 2011 Share Posted January 28, 2011 Damnit, Nistune only posted this morning, won't get it till Monday now . sadface Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5644993 Share on other sites More sharing options...
Traditimeour Posted January 28, 2011 Share Posted January 28, 2011 Ravi, Have you got another actuator to swap over? Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5645006 Share on other sites More sharing options...
mosquitocoils Posted January 28, 2011 Share Posted January 28, 2011 I've got 3 - an R32, R33 and R34 - all have had the same issue Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5645011 Share on other sites More sharing options...
Smity42 Posted January 28, 2011 Share Posted January 28, 2011 coke is awesome. work isn't. transmission ends. Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5645018 Share on other sites More sharing options...
mosquitocoils Posted January 28, 2011 Share Posted January 28, 2011 (edited) Probably a dumb dumb question but one I've never known the answer to Does the diameter or length of vacuum hose make a difference? Specifically in this case intercooler piping nipple -> actuator? Edited January 28, 2011 by mosquitocoils Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5645020 Share on other sites More sharing options...
Smity42 Posted January 28, 2011 Share Posted January 28, 2011 It does but only a minor one. Should try to keep that vac hose as short as possible. Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5645032 Share on other sites More sharing options...
mosquitocoils Posted January 28, 2011 Share Posted January 28, 2011 Yeah I try and keep them as short as needed so that's good.... how about thicker/thinner? Any advantage? Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5645044 Share on other sites More sharing options...
Nee-san Posted January 28, 2011 Share Posted January 28, 2011 Thicker is always better Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5645157 Share on other sites More sharing options...
mosquitocoils Posted January 28, 2011 Share Posted January 28, 2011 Just wait for Martin to read that... Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5645239 Share on other sites More sharing options...
SABBAi Posted January 28, 2011 Share Posted January 28, 2011 Morning Mangs, TFIF. Wonder if I can get away with an 8 hour day today? For Scott: Z32_ECU_Modifications_Direct_R33_Plugin V6.pdf. Booyah, V6. Please don't use the V3 one to do mine . Success Morn. Stuck on a train. Plus side it's fark yeah Friday. I'm on a trian, I'm on a muthaflipping train.... Hmmm i wonder what people would think if they walked past my car and saw my knob covered by a baby sock lol. Very good idea but i think changing knob would be better as i never did like the one i got. Too many knobs in that. Not my idea of a fun night out. Stock manifold (untouched when I replaced the turbo) It's a split dump/front pipe, but not one of the shitty JJR ones, it's got a huge long split for the wastegate gasses. I also checked when I had it disconnected that the wastegate flapper doesn't catch on the interior of the dump (like on the JJR ones)... but that may have changed when I put it all back together..... I'm thinking maybe the gasket could be sitting shitty or something? The wastegate is completely shut at idle. What turob is it? didn't you buy a highflow? It may have a balance issue.... Damnit, Nistune only posted this morning, won't get it till Monday now . Still get to play with the software Correct... Although I can still hear a squealing leak under boost gasket or turbo is my guess. sadface This is for you. oh and scarface. Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5645244 Share on other sites More sharing options...
SABBAi Posted January 28, 2011 Share Posted January 28, 2011 Thicker is always better That's what she said Just wait for Martin to read that... Forget that guy.... Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1492/#findComment-5645249 Share on other sites More sharing options...
