Morning Mangs,
TFIF. Wonder if I can get away with an 8 hour day today?
For Scott: Z32_ECU_Modifications_Direct_R33_Plugin V6.pdf. Booyah, V6. Please don't use the V3 one to do mine :P.
just keep a pair of baby socks in the car, fits perfectly over the gear knob and either stops it from getting hot in first place if you remember to put it on when parking, or protects your hand after the fact if you forget.
Hmmm i wonder what people would think if they walked past my car and saw my knob covered by a baby sock lol.
Very good idea but i think changing knob would be better as i never did like the one i got.
So I unhooked my wastegate actuator hose before work, went for a drive around to warm up (then a bit longer lol)
Anyway, hit around 10-12psi a few times (before backing off), but laggy, and can still hear a balloon squeak type noise.
Dump pipe on incorrectly?
Stock manifold (untouched when I replaced the turbo)
It's a split dump/front pipe, but not one of the shitty JJR ones, it's got a huge long split for the wastegate gasses. I also checked when I had it disconnected that the wastegate flapper doesn't catch on the interior of the dump (like on the JJR ones)... but that may have changed when I put it all back together..... I'm thinking maybe the gasket could be sitting shitty or something?
The wastegate is completely shut at idle.
so refresh my memory
you are getting no boost when everything is hooked up, but when you unhook the feed to the actuator you can get boost?
Probably a dumb dumb question but one I've never known the answer to
Does the diameter or length of vacuum hose make a difference? Specifically in this case intercooler piping nipple -> actuator?
Edited by mosquitocoils
Yeah I try and keep them as short as needed so that's good.... how about thicker/thinner? Any advantage?
Morning Mangs,
Success
Morn.
Stuck on a train. Plus side it's fark yeah Friday.
I'm on a trian, I'm on a muthaflipping train....
Too many knobs in that. Not my idea of a fun night out.
What turob is it? didn't you buy a highflow? It may have a balance issue....
Damnit, Nistune only posted this morning, won't get it till Monday now :(.
Still get to play with the software
Correct... Although I can still hear a squealing leak under boost
gasket or turbo is my guess.
sadface :(
This is for you.
oh and scarface.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
