Evening chaps!
Anyone know much about old ford F100s? Something around 1975-1980 era. Might be looking at buying a beaten up old one for a decent price....... V8 dual fuel... has a slight missfire, checking it out next weekend hopefully but if anyone has any experience with the old ford V8s it'd help.
I was hungover for most of it
Finally got cleared for work so no longer suspended. :down:
Back to work tomorrow, but thinking of chucking a sickie and playing some black ops.... it's habbit now
Morning Mangs,
How was the weekend?
Went and did Q Ride on Saturday. Smashed it so I can go in and get my RE license this morning. Then all I need is to get the bike RWC and regoed and I'm good to go. Hopefully just in time for the rest of the stuff for the GTR to turn up and it won't matter if I'm without it for a week or so.
So what's on for this week. Talk of laserforce last week is that a goer or what?
Morning Mangs,
Evening chaps!
Don't you have enough cars already?
Probably just needs new leads and plugs if it's missing.
Those old dual fuel systems can be a bitch.
Weekend was pretty good. Finally watch The Walking Dead. Was good, need Moar. Not till November though :(.
Also started taking the pool down, which involved syphoning a huge amount of water into the park, where the council had apparently just put down topsoil. LOL.
Nice.
Dunno, ask Scottaaayyy. For the record though, C.H. is now open again.
Edited by Smity42
If i get this I'd either sell the laser, or use the f100 exclusive for our band gear.
Yeah I figured it would just need a basic tune up... the only issue would be the gas system, know nothing about them and couldn't fix it myself. Having said that, if she runs ok on petrol I could just run it like that until I get the gas fixed...hmmm..
burn old steering wheel in a fire?
Martin:
I might have aquired an Iphone, i'm going to shoot mine. Why are you getting rid of the pool? selling it to build a shed??
Ravi:
I'm awesome at fixing american pickup trucks with dodgy electronics, just don't fit a dodgy B&M shifter i can only find reverse when i want drive and 3rd when i want reverse
From a cost effective point of view you'd be better of buying a VW van or something. F100 parts would be hard to source I'd imagine. It would be sick though. Mind you, I used to bum around in an old liberty wagon with a drumkit in the back, two guitars, a bass and two 50w amps. It was cramped, but it worked
F-truck parts are easy to come by, theres lots of them on the road and most of the parts aren't anything special
mmmm.... fire.
Keen to watch. Or, reckon we can go to southport indoor pistol club and pwn both of them with hand cannons?
Fence doesn't meet new council requirements. Filter is f**ked. Pool is rusty.
Basically needs a shit tonne of money to be able to keep it and totally not worth it since it's always full of aids anyway.
Am going to try and convince dad a shed will go there nicely...
Truth. Although I still think my plan to fix it was just as awesome.
I always said you got your licence in a cereal packet.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
