cricket is a game i watch while drinking, not play for a competitive thing. I'll play drunken beach/ backyard cricket though.
Scott, really need a brumby box :(
Morning Mangs
We have a cricket team.
ooooo that is good.
But it is indoor.
Oh that is bad.
Um... what?
Pfft, its not really competitive. We take ourselves less seriously than the australian cricket team (and that's saying something ;)). Also there is a bar there, and you can get sloshed before you play if you like.
tehehehehehe... box...
Nuffing.
Maybe... :whistling:
Morning all
A likely story...
Sarp Mangs,
Busy Day.
Same. Busy day, busy week, busy few months :(
LaserRape update?
Erm yeah, this def needs to be organised before tomorrow afternoon if we are going tomorrow...
So I have another few days before I head back to Brisvegas. Once I'm back I have another week off work, time to get working on some simple stuff for my baby. Want to get the intake side of things sorted first, how hard is it for someone with limited knowledge to rip out an air box and replace it with a pod filter and a CAI for it?
Ridiculously easy - undo 4 bolts, remove box, insert adapter plate + pod together, bolt up
CAI = agi pipe and cable ties are your friend ;)
I really should own a 31 shouldn't I
So where is Scott? I expected him to chime in with some Lazercaust details
Dunno. He's probably nicked off with my ECU and Nistune :P
So strayan day today. Might have to design a CAI for the car.
Wait there's no beer in the fridge, no good.
N.G. :(
In short I beleive she is saying indoor cricket is strictly for homos!
Ahh I see. Furry Muff.
Yes you should :thumbsup:
I'll sell you a 31 ute ;)
Turbo is sent off bitches, was rediculously expensive to send express so its just registered post. Hopefully I get it back by next weekend...
Thanks Jezza. f**k people in cars eh...I saw a rear ender yesterday on Coro drive and was thinking f**k if that was me I'd be f**ked :pirate:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
