Hard suspension, lots of negative camber, Mechanical diff and ages old rock hard second hand rubber is the formula for doing a fully sick skid bro
What qualifies as 'hard' suspension? Coilovers? Or could you get away with simply lowered springs + adjustable sway bars etc etc?
Probs going to head to BNR meet on thurs even though GT-R is sick.
I think they are playing electrophaggotry ( laser tag) instead?
Cool. I had never seen anything like it before, haha.
if you have adjustable suspension set your dampers in the rear to hardest and go for a drive...you will soon see how they do it!
Well I'm a fat bastard and fat bastards like me don't like to run so I might give Pew-Pew-Pew Starship Troopers a miss. However, I'm a fat bastard and fat bastards like me do like Ice Cream so I might come along later to BnR :P
Morning all.
Miso have you got names for them yet?
Pretty sure BNR is still on this week. Electrphaggotry is only for an hour or so and I think we'll be heading to BNR after that which will be around 9ish.
Hopefully I'll have my baby back from the guys at Fulcrum today. Will be good to not have it constantly bottoming out and rubbing on the guards every time I hit a bump or corner at speed.
I'll be at BnR around 9ish tomorrow. Hope to see a few of you there :)
sorry didnt see this here before
Coilovers with the dampers wound right down and very low springs would likely do it too, anything that limits travel and absorbing the shock effectively really.
Know much about fixing an effects pedal that won't power on?
It's a korg ax3000g
Dude those korgs are old! I thought my boss gt3 was the oldest thing around lol. Glad I sold that actually. Loving my podxt live :)
ANYWAY...... not really, short of checking/replacing the power supply you could maybe open it up and check around the power jack and the leads going away from it. That's easy enough to do.
Any more than that and I can't really help though :(
with fire
This is probably easier.
You can still buy them! It's actually a mate of mines, his ball and chain bought him another one cause this one was stuffed.
I would have personally bought something else but women, you know..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
