Decided this is the phone I want: http://www.gizmodo.com.au/2011/01/samsungs-infuse-4g-a-spectacular-google-android-phone/
Unfortunately its not out yet :(, and who knows if it will come to Australia at all...
Fortunately the at&t one should work on Telstra's network, so I think I will switch to Telstra when my current contract is up and take whatever the best free phone they give me is, and then get the infuse from the US when it comes out
McFly, I'd wait and see what Samsung do for an Australian infuse. I've heard talk of a new Galaxy soon which seems to have the same specs. And I would Talk to Telstra's tech division and double check compatability. I nearly bought a Samsung from the states a few years back and then found out it wouldn't work here even though it seemed like it should.
So who's right to help out with moving on Saturday March 5th? Trying to work out how many mangs can help so I can work out how smoothly it will go. Have secured the ute from work, but need help lifting and possibly pulling things apart. Coukd do with more utes/big cars too if they're available :thumbsup:
Free lunch for whoever can help :)
Eventful weekend was eventful.
Tattooed from around my elbow up to chest on my left side now, stings like a motherbitch in this sun. Also had band practice and making significant progress! Things are coming together stupidly well now.
The clutch in the missus's's's car failed friday afternoon... not sure where the problem is but it's in at Midas over at Mansfield. Never heard anything GREAT about Midas but it was the only "reputable" place close enough to get towed to. Fingers crossed it's not bad...
German club closed sundays... epic poor planning. Need to reschedule for another night. Suggestions?
I can make no guarantees but I will try to make myself available to help. Will have the sexF if I do.
sounds like problems.
I moved house, all done in a sunday afternoon :)
Now thats an organised man, took me 2 f**king months just to clean the room out in my old place Lol
Morning Mangs,
Hella busy Saturday. Epic lazy Sunday. :thumbsup:
Last week before uni starts again. Hurray for 40 hour working weeks :cheers:
Oh ffs no staff again! One has severe sunburn and cant come in for 2 days? >_<
One of my guys said the same last week. Told him he was weak as piss, but when he actually showed up 2 days later he looked like a leper.
So I gave him a pat on the back for coming in anyway. :laugh:
I just remembered: The security guard on the gate this morning said my XF was a "Nice old rig" (or something like that). I didn't know what to say, it's such a shitheap. I just laughed.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
