I get 300km per tank... If I'm lucky. Usually it's 280km per tank :(
i think i get good economy now john lol.
the needle is on the e and i normally have done around 380-400km. i dont wait for light.
Also some good news, wife got rear ended in the skyline today. Tool in a ute apparantly "rolled" into her as she was stopped at the lights. Damage minimal. Scratches on rear bar and gouges from the number plate on it as well.
I think it has also pushed boot out of alingement. Biggest issue is that my wife hurt her back quite badly. she started getting sore when she got home. Can i get the guy who hit her to pay for medical costs? I have the fun job of ringing his boss tommorrow to work out what he is going to do about it.
Some people should never get a license.
oh and if any one is thinking about joining a gym to get fit .... dont. The pain after your first weight session should be illegal. i cant bend my arms!!!
Edited by Kiwibob
yeah go american style and totally over do it!!! sue everyone and anyone who was watching. i hear countries and reputations are built on it
average 450 here/ best was 640. and only got 56ltrs back into it (warego highway for hours straight at 115)
Edited by boiracer
i get my best on the moonie highway between a little out of dalby and 30km past westmar. Then it all gets messed up on the 37km of gravel ;)
When I drove from brisbane to mackay in the coon I had an average of 7l/100km. Without cruise control it sits at about 5l/100km/h and with cruise control it's about 6.5.
Around town is about 12/100 because it's auto and i drive in some traffic each day. I think the most I ever saw it was 890 to a tank.
Edited by hylian
I feel better now, lots of people getting much better economy then I am. It must be a problem with my AFR's and a dodgy pair of injectors/fuel pump. Oh well better get the injectors and pump replaced with better after market ones and get a new ECU and a full tune to sort it out.
*shifty eyes*
great, i've got a throat infection. Can't stop coughing. I'm not supposed to have anything cold either. Pain in the arse. Hopefully these antibiotics will clear it up somewhat fast.
have you tried turning it off and on again?
Have you checked that the power cord is plugged in?
Hello IT
Have you tried turning it off and on again?
The button on the side is it glowing?
Yeah you've gotta turn it on.
Push the button!
My ifail has an app for invision boards so that's how I get on here. I just look really frustrated and they think I'm busy and send me a message on communicator instead of talking to me
Edited by hylian
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
