Sarp mangs. Had a quote for all the stuff for the GTR. $1400 from Jimboomba Smash Repairs. But they're booked out out till April ish. So I'll be taking it to a few other places and shop around for a better price. Any ideas?
Oh yeah we had our first pre season game today against Park Ridge. Played against their div 3 and div 1 teams, ended up winning 6 - 0. Very pleased. Now I'm chilling at home watching Jurassic park lol. Back in work tomorrow going to have shitloads to catch up on pinch.gif
What are you getting done mang ?
Fourthly, you're still a cockhead for posting in the exhaust thread.
And YOU'RE a cockhead for coming in here, insulting a bunch of people who functioned quite well before you 'graced us with your presence' and continuing to do so when everyone CLEARLY wants you to shut up and leave.
Hes a farken classic isnt he. Got his arse booted off one forum and now doing his best to make it 2.
I hope they dont ban the lyin pos shit tho. Havnt had a chew toy like this for ages.
Go get him mate :thumbsup:
  • Like 1
  • Nope 1
'sarright mate, you can wear it like a badge of honour if it makes you feel better.
Incase you haven't noticed in the last 3 pages, pretty much every reply you have made has been ignored, because you are noone. Kindly hang or impale yourself with your keyboard, whichever you prefer, maybe you should join nee-san and boiracer in sydney.
  • Like 2
  • Nope 8
Oi Ghosty I'm sure you now have plenty of spare time on your hands since being banned on SD - however take your shit else where.
  • Like 2
Cool story, Hansel and cool theory... apart from at least two posts I can think of that mentioned his name and related directly to him.
Would you like some coffee with your humble pie? Or would you rather just choke on it?
  • Like 1
Which Tristan is this, blue 180?
  • Like 2
  • Nope 4
Cool story bro.
Just as I suspected, you have no idea, and noone will tell you either.
First rule of fight club Waku-Houku...
Yeah thats right, I know tonnes of ppl on SD. Not bad for a nobody hey?
And what was that about no-one would tell us?
Of course, For being the same douche you are everywhere else.
Looks like you were pretty much spot on. Thanks for playing, ghosty :thumbsup:
  • Like 2
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
